Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > John Deere > JD Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
LinkBack Thread Tools Display Modes
Old 05-31-2007, 11:10 PM   #31 (permalink)
Default Re: I-match bushing question
Thanks for the added info. I still can't seem to find them online. I'll have to check my local dealer and see if he has anything.
__________________
Dave
pekabu is offline   Reply With Quote
Old 06-05-2007, 10:42 AM   #32 (permalink)
New Member
I was just at TSC here in Ontario and TSC Canada does not deal with Speedco. But they are going to try finding another supplier. I'll keep you posted.
classic is offline   Reply With Quote
Old 06-05-2007, 12:07 PM   #33 (permalink)
Gold Member
BlacknTan's Avatar
Isn't it possible to replace the Cat 1 pins on the implements with Cat 2 pins? No bushings required, but, the implements would not be available for Cat 2 usage, if you were to lend them..
BlacknTan is offline   Reply With Quote
Old 06-05-2007, 10:46 PM   #34 (permalink)
Loogie's Avatar
Sometimes the holes in the implement for the Cat 1 pins are too small to accept the threads of a Cat 2 pin. Depends on the implement. Can't hurt to try. I'd measure the hole then measure the pin threads at the store.
__________________
JD 2305, 200CX Loader, 62" MMM w/ mulch kit, Frontier 2048L Box Blade, Ballast Box, iMatch, ATI toothbar, Paynes forks, lots of learning to do...
Loogie is offline   Reply With Quote
Old 06-06-2007, 11:37 AM   #35 (permalink)
Just as an update. I order the part PM03015 (as I attached earlier) from my dealer. They arrived and are exactly like those pictured in the TSC post, although only one per pack with one roll pin.
So one bushing (with the big end) including a roll pin for $12.95 canadian or $9.95 from US dealers. That equates to about $25 per pair in CDA and 20 per pair in the US. Equal to TSC in the US, I suppose. And waaaaaaaaaay less than the quoted $130 per set for the other part listed by the canadian dealer!!
I can't confirm yet how well they fit or if I need a cat 1 to 2 bushing between the implement pin and the new bushing part. I assume I do, but I bought those at TSC for $3-5, so I'm OK there.
mx125 is offline   Reply With Quote
Old 06-06-2007, 04:48 PM   #36 (permalink)
prosperity's Avatar
That's great to hear - a little home work and patience paid off!
prosperity is offline   Reply With Quote
Old 06-06-2007, 06:37 PM   #37 (permalink)
Quote:
Well . . mostly help for you guys . . .but i guess that counts as homework!
Thanks again. I hope other Canadian read this and save themselves money. JD Canada has to pull things together and ship the I-match with proper bushings and information to the dealers!
Old 06-10-2007, 07:29 PM   #38 (permalink)
New Member
I got the I match on friday. A set of the bushing with the bigs ends ran me 40.00+2.5 tax
jamesa is offline   Reply With Quote
Old 06-10-2007, 07:57 PM   #39 (permalink)
Gold Member
BlacknTan's Avatar
Are they heat treated??
They appear as if they could be.
I can't imagine what would make something so simple be so expensive....
Old 06-11-2007, 09:17 AM   #40 (permalink)
The color pics posted in this thread are all the JD kit. Here is the last one in the set (I took them all) showing the JD part number:
I am not sure about the heated treated part, but the black bushings are finished in black oxide. They rust very easily. I would get the speeco units which are zinc coated and likely won't rust. And the Speeco units have fewer parts.
jeepinator is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
