4320 Replacement Battery Any options?
   / 4320 Replacement Battery Any options? #1
TnFarm
Member
Tennessee
John Deere 4320
Yep, my battery is leaking. My tractor is a 2006 and noticed over the winter the corrosion. It's still under warranty but thought I would clean it up and replace the battery myself. I logged on to search about the Optima but all I can find are the threads about it being discontinued. Figured Deere would just replace with a new battery which would just leak again. Are there any options for replacement batteries that wont leak? Also has anyone had any luck with new batteries from Deere? Thanks for any help.
Hopefully my problem is solved. After neutralizing the acid and cleaning the rust, I went out and picked up an Optima Redtop. I had to make a couple of minor modifications to make things fit but it is in and ready to go.
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
Compact Track Loader Skid Steer (A59228)
Compact Track...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
