Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > John Deere > John Deere Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 08-08-2008, 12:45 AM   #1 (permalink)
Engine66's Avatar
Default Power Steering GPM Flow vs Total Implement
I have a 4720 w/ehydro and was wondering if the power steering pump and implement pump are completely seperate or if they are inline together as one circulatory system? I recently had a rockshaft valve replaced under warranty that was making a harmonic whine in the the 3PH. I also had a transient vibration and whine from the steering wheel. Dealer said the system was one and the same, but brochure/literature shows PS pump at approx 5 GPM and implement pump at 11+ GPM. So question is, could the PS pump be causing the vibration and whine? This problem is very minor and does not affect the operation...it's just something I have noticed when I work the tractor hard clearing some land. I did read some others with same tractor say they too had similar sounds, etc with PS. Any thoughts? I'm at about 65 hours and otherwise the tractor is a BULL.
__________________
Tonight Could Be The Night
Engine66 is offline   Reply With Quote
Old 08-08-2008, 01:42 AM   #2 (permalink)
Gold Member
Default Re: Power Steering GPM Flow vs Total Implement
Engine66,
Your 4720 has back to back pumps for the power steering and the implements. They are driven by the same gear, share the same hydraulic supply line, but have separate sets of gears and separate output lines.
I won't venture a guess as to the cause of your whine or vibration. I'll assume that you know that you'll get some whining from relief valves when you try to do something the hydraulics can't handle. Shouldn't be any vibration from that, though.
As a warning, your pump costs $514.50, and it appears that they don't sell any parts (like seals, for example) for it, only the pump as a unit. So think twice before you disassemble it!
TedLaRue is offline   Reply With Quote
Old 08-08-2008, 06:53 PM   #3 (permalink)
Engine66's Avatar
Ted...thanks for the very informative info. I'll double check with the dealer on this vibration in the steering wheel. Regards...
__________________
Old 08-09-2008, 09:05 AM   #4 (permalink)
Quote:
My 4720 had a vibration in the wheel. There was a tech update on doing some isolation of the column, etc. NOte: It was worse when it was cold. It did not fix it 100% but it is acceptable now.
D.
__________________
Darin Divinia
Red Oak, Texas
Registered Texas Longhorns
www.thediamonddranch.com
JD 5525, JD 4720, JD 467, Polaris Ranger Crew, etc.
ddivinia is offline   Reply With Quote
Old 08-09-2008, 05:23 PM   #5 (permalink)
Engine66's Avatar
Quote:
D.
D,
I recall an earlier post where you had a similar problem. I wonder if the pump is the problem or is the column the problem. When you say isolating the column, do you mean they insulate it at connection points to dampen the vibration...kinda like how motor mounts isolate vibration? Bottom line is, what is the vibration's source...pump or what? It feels to me like the pump, but I am no expert and still new to the 4x20 series. I will call my dealer Monday about what you said. Any other info you can share would be helpful...my dealer has been really outstanding...thanks!
__________________
Old 08-09-2008, 10:12 PM   #6 (permalink)
D,
I did not change anything on the pump or hydraulics. I believe the issue was vibrations from the hydraulic system into the column/wheel. JD Engineering has a service bulletin on it.
D.
__________________
Darin Divinia
Red Oak, Texas
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
