Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > John Deere > John Deere Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 08-27-2008, 08:36 PM   #1 (permalink)
New Member
Default 62D gage wheel shafts breaking on 2520
I wanted to post the question here and see if anyone else has had issues with the gage wheel shafts on the 62D breaking? I have had both front shafts split through the center of the lowest adjustment hole, and earlier in the month one rear shaft sheared where it is pressed into the arm. I own one of the first 2520's off the line (delivered Nov 2005), and the deck has a serial number that ends in 00014. I think it was #14 off the line by the looks of it. The machine has been out of warranty since Dec 2007, and each front shaft was $50 and the rear $25. This was the first year that I used the deck for a full season, the previous time was spent with the loader and bush hog mostly.
I believe that the flat wheels did a number on the front shafts when they did not turn correctly. The front shafts broke within 2 weeks of each other which was also odd. I called the 800 number for Deere and reported the issue and they quickly handed it off to the dealer who has yet to call me back on the issue. I will have to talk face-to-face with them when I pick up the rear shafts. Also the rear shafts took 3 weeks to arrive to the dealer.
Thanks to this board I did get the modified wheel kit for the 62D and the dealer worked with me for them.
The only issue I have had with the machine is with the 62D. I just don't want to have to spend $150 a season on parts that should be engineered to be used on a tractor of this size and not break in a single season.
Anyone else break a gage wheel shaft?
curley is offline   Reply With Quote
Old 08-28-2008, 02:59 PM   #2 (permalink)
New Member
Default Re: 62D gage wheel shafts breaking on 2520
Curley
Got my 2520 in July 2006 and have 340 hours on it, a lot of the time mowing.
I have not broken any of the shafts, but I've bent them pretty good a couple of times.
The times I have bent the shafts have been when I've gone on rough ground ( not to mow) and didn't bother to remove the deck. With all those large holes, for height adjustment, the shafts are fairly weak.
The fronts swivel around and on slightly side sloped terrain they will be sideways to the direction of travel. A rough spot will catch the wheel and take a divot or worse. The newer rounded wheels should be a big improvement.
I keep the wheels adjusted above the ground, so they don't dig in, but still pick up the high spots in the lawn to prevent scalping. Keep everything greased.
goodbyeNJ is offline   Reply With Quote
Old 08-28-2008, 04:25 PM   #3 (permalink)
New Member
Your wheels are not gage wheels they are anti-scalpe wheels. They should be running 1/4 to 1/2 in off the ground. If you do run them on the ground you will have the problems you describe. The deck will mow a lot smother yard with the wheels off the ground also.
gfd_703 is offline   Reply With Quote
Old 08-28-2008, 10:31 PM   #4 (permalink)
New Member
I do have them adjusted properly. They are at least 1/2 inch above the ground when I setup the height over the shop floor before mowing. I do have many contours on my property but nothing really hilly. Also I remove the deck when I am doing anything else with the machine (Bush Hog/Tiller/Box Blade/Loader). I try really hard to not abuse any of my equipment like most of us on this forum. We pay a lot for these machines and expect them to last for many years. When I think that I paid as much for a mower deck for this machine as an entire throw away riding mower from Lowes or Home Depot I guess I expect it to perform. As I said before the 2520 has been great and never let me down with the exception of the deck (wheel shafts and cable for the ind. lift). I am just really disappointed in the setup of the 62D on the 2520.
As for calling them gage wheels, the part from deere is called out as a front and rear gage wheel in the online parts catalog. Also I know this is a "floating" deck and don't let it ride on the wheels when mowing.
From now on I will have the adjustments for the wheels up a notch higher than needed so that the part of the shaft below the mount is solid steel and not a open hole. I hope between this and the improved wheel design with grease fittings installed will keep this from happening again. I will cross my fingers!
Old 09-07-2008, 04:09 PM   #5 (permalink)
New Member
I have had one of the shafts bend and also feel the 62MMM wheel system is a weak system with POOR engineering.
My 2520 with the 62" MMM deck rips up the lawn. I have had the new round profile wheels put on it and it still does it. Not as bad as the old square profile wheels, but it still does it. There is not enough offset in the axel to make it caster correctly. Today I put on the three bag power bagger system. You are supposed to run the right set of wheels 1 hole lower to help support the weight of the blower. Now it is worse again because the deck doesn't sit level with the power blower on it so the right wheel tears up the lawn. It gets sideways and won't straighten out till it makes a trench. Does anyone have a fix for this or have they had any luck with JD. I have another complaint into them but haven't heard back yet.
I love all the attachments with the exception of the deck and bagger system.
__________________
2520, FEL, 47" snowblower, Mid mount mower, pallet forks, quickhitch
wingsaircharter is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
