Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > John Deere > JD Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 04-09-2001, 12:48 AM   #1 (permalink)
Default 850 Doesnt Start
1987 850, 2wd, 294 original hours. Have power to the ignition, all lights work, turn the key hear a click and nothing. sometimes it starts right up. i was thinking the solenoid on the starter.. Not sure though, anyone have any thoughts?
greenmachine is offline   Reply With Quote
Old 04-09-2001, 02:10 AM   #2 (permalink)
Default Re: 850 Doesnt Start
Right now it's late so my head is foggy.....But I am thinking that you don't have enough cranking amps in your battery to turn it over.... eventhough your lights work does'nt mean that your battery is up to snuff I think. But like in the past I could be wrong. O.K. seems to be quit often..LOL I am sure you will find some troubleshooting quides here in the morning from people that actually know something [img]/w3tcompact/icons/blush.gif[/img] [img]/w3tcompact/icons/smile.gif[/img]
Darin
DarinRay is offline   Reply With Quote
Old 04-09-2001, 08:10 AM   #3 (permalink)
Epic Contributor
Bird's Avatar
Hearing a click would indicate to me that the solenoid is doing its job; opening and closing the circuit. Like Darin said, I'd start by checking voltage at the battery, then I'd check for loose or corroded connections, check voltage at the starter, and with a clamp meter, check amperage draw on the starter cable when the key is turned to the start position. If all that checks out good, I'd remove the starter and check for damage to the bendix drive, and as a last resort, the possibility of damage to the teeth or gears on the flywheel. If it works sometimes and sometimes doesn't, it's possible the starter drive and flywheel teeth just aren't lined up to go together. And I'm not a mechanic, so those are my guesses and opinions; someone else may know better.
Bird
Bird is offline   Reply With Quote
Old 04-09-2001, 09:03 AM   #4 (permalink)
Super Member
I completely agree with Bird. Last year the massey did the same thing. Had brand new batteries and about a week later it started clicking and then after bumping it enough times it would finally catch and start. After a few months of that no matter how many times I clicked it it wouldn't start so went and got a new started solenoid and it started everytime right off.
The skidsteer though one time did the same thing too. On that occasion it was the negative battery terminal connector was loose. I tightened that up and it started right off.
cowboydoc is offline   Reply With Quote
Old 04-09-2001, 12:19 PM   #5 (permalink)
I was going to test the power to the starter this morning. The clicking does sound like its coming from the starter but a relay underneath the diesel tank, this isnt my tractor so i am not to familiar with it.. I am used to worked on JD farm tractors.. I will check the basics and let you guys know what i find. thanks
Old 04-09-2001, 04:57 PM   #6 (permalink)
Its not the starter or solenoid.. If i run a hot wire from the battery to the starter solenoid it starts right up.. So i now going to replace the relay in the ignition system. Its a small round relay and it is right next to the tach after u take the access panel off. Hopefully that will solve the problem.. Thanks!
Old 04-09-2001, 05:16 PM   #7 (permalink)
Epic Contributor
Bird's Avatar
Aaah, I assumed the click was coming from the starter solenoid, and of course, I'm not familiar with that model, so it has a relay I didn't know about - nothing too new about me not knowing what I'm talking about.[img]/w3tcompact/icons/laugh.gif[/img] Glad you got it solved.
Bird
Old 04-09-2001, 08:19 PM   #8 (permalink)
New Member
PC 1876-850 (-016000) AND 950 (-020000) COMPACT UTILITY TRACTORS ELECTRICAL
INSTRUMENTS
KEY PART NO. PART NAME QTY SERIAL NO. 0 0 REMARKS
1 CH13574 NUT 1 M6, (SUB FOR CH12382)
2 CH11698 FLASHER 1 (LESS TURN SIGNAL)
3 CH11895 SPACER 1
4 24M7054 WASHER 1 6.400 X 12 X 1.600 MM
5 21M7094 SCREW 1 M6 X 16
6 CH17992 COVER 1
7 CH12037 SCREW 2
8 CH12768 BULB 3 1.7 W
9 CH11893 TURN SIGNAL LAMP 1
10 CH11982 NUT 1
11 CH12209 KNOB 1 013828- X
CH12209 KNOB 1 017641- X
12 CH12210 SCREW 1 013828- X
CH12210 SCREW 1 017641- X
13 CH18036 SWITCH 1 013828- X LIGHT
CH18036 SWITCH 1 017641- X LIGHT
14 CH12200 SWITCH 1 -013827 X LIGHT
CH12200 SWITCH 1 -017640 X LIGHT
15 CH12206 KEY 1
16 CH11696 SWITCH 1
17 CH13720 RELAY 1 009001- X
CH13720 RELAY 1 012001- X
18 14M7229 NUT 2 M5
19 12M7064 LOCK WASHER 2 5.100 MM
20 CH12768 BULB 1 1.7 W
21 CH20169 SPEED-HOUR METER 1 (SUB FOR CH12235)
22 CH12241 CABLE 1
DONOTDELETE is offline   Reply With Quote
Old 04-09-2001, 08:33 PM   #9 (permalink)
New Member
If not the relay... how about a "safety interlock" device partially hanging up?
Old 04-10-2001, 12:12 AM   #10 (permalink)
I need a break down of the rear hydraulics, the quick disconnects are leaking, must be a few o-rings inside that are leaking.. Since its not mine i dont have a service manual.. So if anyone could help me out i would appreciate it! Thanks!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
