Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > John Deere > JD Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-09-2006, 03:02 PM   #1 (permalink)
Member
Default 2305 break in and oil change
My dealer told me that ther isn't any break in required for my tractor and that I should work it as hard as I want to right away. I always heard that you should vary the engine speed and load for the first 50 or so miles. What do you guys think ?
Also, they said that I should change oil after 8 to 10 miles because of shavings. I thought that the break in oil should stay in longer than that.
Any thoughts ? I am very confused now.
planman8 is offline   Reply With Quote
Old 11-09-2006, 03:28 PM   #2 (permalink)
Gold Member
Default Re: 2305 break in and oil change
You should use the machine as wanted, vary the speeds and enjoy. As for the first service, I would wait until 50-hours, that is break in oil in the machine and you really want to seat components.
johndeere_2210 is offline   Reply With Quote
Old 11-09-2006, 03:51 PM   #3 (permalink)
JDFANATIC's Avatar
planman,
Ditto what jd said above. Nice family you have there. Maybe jd will post his family pic too.
__________________
Cheers!
JDFANATIC
JD2210, 62" MMM, 210 FEL, 48" York Rake, 46" Snowthrower, loaded turfs, PTO Spreader, Heated Cab, Plug Aerator, FIMCO Sprayer, Folding Rops
JDFANATIC is offline   Reply With Quote
Old 11-09-2006, 09:10 PM   #4 (permalink)
New Member
Good question Planman. I just bought a 2305 about a month ago and have read many varying opinions on the first oil change. I have not been babying my new tractor by any means and am just running it as I need to. My friend saw it today and said "man this thing is dirty." I told him "I bought it to use it!" Actually we've had a lot of rain, and it's muddy back there. I digress... my research led me to the 50 hour mark for the first oil change as well.
__________________
Paul
John Deere 2305, 200CX FEL, 48"BB, 54" MMM, loaded tires, More stuff: http://web.mac.com/pdkres/iWeb/Deere/Home.html
Deerfoot is offline   Reply With Quote
Old 11-09-2006, 10:29 PM   #5 (permalink)
Gold Member
Send a message via Yahoo to orlo
Hi:
On my 2305 my dealer (An old time dealer selling tractors for years) said it's better to wait until 75 or 80 hours to make sure all the seals are seated. I've heard that opinion elsewhere also.
One dealer who did my service did mention the 10 hour break in but he's the only one. The manual states nothing of this. I suppose it would make sense to get any metal particles out of the oil but anything of significant size the filter would catch anyway.
__________________
"I'd rather be on my Tractor"
orlo is offline   Reply With Quote
Old 11-10-2006, 09:46 AM   #6 (permalink)
Member
What about changing oil at 10 hours and then putting break in oil back in until 50 hours ? I guess jd sells break in oil don't they ?
Old 11-10-2006, 12:24 PM   #7 (permalink)
Gold Member
You can purchase Break in Oil at Deere or elsewhere. If you are worried about shaving in the system and feel strongly about doing something before the 50-hours then I would suggest you do one of the following:
a) change the filter only and top off with break in oil.
b) change filter/oil and go back with break in oil.
Old 11-10-2006, 09:00 PM   #8 (permalink)
New Member
bigreddmax's Avatar
According to the JD manual, break-in oils should not be utilized.......
"John Deere PLUS-50 oil is recommended. John Deere TORQ-GARD SUPREME and oils meeting ACEA Specification E4/E5 may also be used.
Other oils may be used if they meet one or more of the following: API Service Classification CI-4, API Service Classification CH-4, or ACEA Specification E3.
Multi-viscosity diesel engine oils are preferred. Do not use break-in oils. "
OMLVU16738_H5
__________________
JD 2305 200CX Loader, 62" MM, 5' Frontier Back blade, MODS: X Series suspension seat, rear 12V outlet, ROPS lights:Forward and Rear
bigreddmax is offline   Reply With Quote
Old 11-24-2006, 03:12 PM   #9 (permalink)
New Member
I suspect break-in oil is not recommended since JD Break-in oil is not multi-viscosity, it's an SAE 30 viscosity. JD-built diesel engines are factory-filled w/ JD Break-in oil, the 2305 has a Yanmar engine so not sure what it's filled with originally. I wouldn't hesitate to use JD Break-in oil in any diesel engine provided ambient temps are within SAE 30's acceptable range. I would also perform an early oil change without fail since cleaning an engine's internal oil passages are difficult & a lot of crud can be left behind from manufacturing/assembly. I'd refill with the same oil put in by the factory after doing this first service. Maintenance intervals are driven by conflicting demands between marketing and engineering, engineering is more likely to be conservative.
justwork is offline   Reply With Quote
Old 11-24-2006, 08:12 PM   #10 (permalink)
RalphVa's Avatar
I changed to 5w30 Mobil 1 at 13 hours. Changed it again at 113 hours and plan to do it again this spring, probably at around 200 hours. Still using 5w30 Mobil 1. Doesn't use any oil nor blow blue smoke. Uses 0.45 gallons/hr of fuel.
Ralph
__________________
The natural gardener
God's original intent
RalphVa is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
