Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > John Deere > John Deere Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-27-2006, 04:22 PM   #1 (permalink)
Default 3520 ERROR CODE 05
I was out grading up a road today and went to set the cruise control and error code 05 came up and the cruise function did not work. Shut it off and restarted. No code. Pushed the cruise switch and code came up again. I finished what I was doing and then looked in the manual.Err 05 Brake and Cruise Set/Decel Switch. ( PROBLEM SOURCE: Cruise control set/Decel switch depressed while brake is engaged.) (ACTION: Release brake pedal.) But the brake pedal was not depressed or PARKING BRAKE was not set.
So I thought I would disconnect the battery and see if that might clear it. If that did not work I was going to check out the cruise switches to see if one may have come loose.
But, before I do that maybe pull up on the brake pedal. Shazzammmm! That was it.
__________________
"Good judgement comes from experience.Experience comes from bad judgement."
dirtworksequip is offline   Reply With Quote
Old 11-27-2006, 10:04 PM   #2 (permalink)
GreenMtns's Avatar
Default Re: 3520 ERROR CODE 05
Glad that work out so well. Most little bugs don't.
Does your 3520 have the automotive cruise control or just the standard one button control?
Al
GreenMtns is offline   Reply With Quote
Old 11-28-2006, 07:12 PM   #3 (permalink)
It came with the standard cruise and I installed the auto style optional cruise.
__________________
Old 11-30-2006, 07:47 PM   #4 (permalink)
My 3320 had the same problem. I have the automotive style cruise, and found the same cure. Wish JD had put it in the operators manual as a quick check. I rarely hit the brake so it was up, but probably stuck the switch from lack of use.
tglass is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
