Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > John Deere > JD Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
LinkBack Thread Tools Display Modes
Old 03-04-2007, 09:15 PM   #11 (permalink)
New Member
Default Re: New Green 2305
Quote:
Originally Posted by Shawk
Hey Mayor... can you snap some close up shots on which wires your lights hook into? My 2520 had additional wires to run. But the only wire I found to run my 2305 lights off was the tail light wire. Thanks...
there is a set of work light wires under the left rear of the tractor. under the rops. you can follow the wiring harness to find them.
__________________
John Deere 2305, 62''MMM, 200CX Loader, I-Match, Frontier RB2060, Ballast Box, Tooth Bar(homemade),Aux Work Lights, 403 JD Rotary Cutter, Towbehind Sprayer, STIHL 290 20'' bar, STIHL 210 16'' bar, STIHL FR55S, STIHL Power Broom
buddygunzz is offline   Reply With Quote
Old 03-04-2007, 11:00 PM   #12 (permalink)
New Member
Buckeyenut's Avatar
Outstanding!! Thank you Buddygunzz!! That's exactly what I was looking for!!!
__________________
JD 2305, 200CX loader, 62C MMM, 4' Frontline box blade, 6' Howes grader blade.
Buckeyenut is offline   Reply With Quote
Old 03-04-2007, 11:57 PM   #13 (permalink)
Gold Member
Shawk's Avatar
Quote:
Thanks Buddyg... found those. I was wondering if there were any others. Those are pretty skinny .... but I know they were'nt meant to run 3 lights like I have. I'll put a switch in to run no more than 2 accessory lights at a time. Appreciate the reply...
__________________
JD 2305, 200CX FEL (53" bucket), 62C deck, Landpride 54" Bx.B, JD 47" Snowthrower, JD 60" RB, Frontier 3pt Spreader, Ballast Box & i-Match...
Shawk is offline   Reply With Quote
Old 03-05-2007, 03:22 PM   #14 (permalink)
Gold Member
cast_and_blast's Avatar
Looks great! When can I borrow that tiller?
Scott
cast_and_blast is offline   Reply With Quote
Old 03-05-2007, 09:26 PM   #15 (permalink)
New Member
correct me if im wrong but those 2 wire are 14 gauge which should care 15 amp no problem and im running 3- 55 watt light and have 14.1 amps on the circuit. i do have a 15 amp fuse in the fuse holder.
wire chart amp.
AWG / Amperage (Up to 50' wire length)
AWG max. Amperage
0000 (4/0) 300 A
000 (3/0) 260 A
00 (2/0) 225 A
0 (1/0) 195 A
2 125 A
4 90 A
6 70 A
8 50 A
10 30 A
12 20 A
14 15 A
16 10 A
hope this helps
__________________
Old 03-05-2007, 09:32 PM   #16 (permalink)
Mayor's Avatar
Thanks for your help with the lighting questions. Have not had time to take any pictures.
__________________
2305, 200CX, MMM, iMATCH, Frontier Box Blade, Weight Box, Markham Welding Toothbar, JD 826D Snowblower, Toro Super Recycler, Stihl KM55R Power Unit, FS Line Head, FCS Str Edger, Stihl HS45 Hedge Trimmer, and Still FS80 Brushcutter, Stihl BG85 Blower, Star Sprayer,Herd M96 Spreader.
"From birth, man carries the weight of gravity on his shoulders. He is bolted to earth. But man has only to sink beneath the surface and he is free" Jacques Cousteau
Mayor is offline   Reply With Quote
Old 03-05-2007, 09:32 PM   #17 (permalink)
Elite Member
kennyd's Avatar
Thats why it is recomended to install relays and additional switches, It keeps the added load off of the factory harness and switch.
My lights:
http://www.tractorbynet.com//forums/showthread.php?t=69583
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, Imatch, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, and much more "stuff"
kennyd is offline   Reply With Quote
Old 03-10-2007, 10:18 AM   #18 (permalink)
Mayor's Avatar
Hey guys,
Just finished my tool box add on and I think it came out ok. Took a few shots as I went along. Let me know what you think. The seat is all the way back and it only hit the tool box when getting on. The rubber strip keeps it from messing with the finish on the seat. This is a $35.00 project and it was very easy to do. Hope you enjoy the shots?
[IMG]http:http://i37.photobucket.com/albums/e99/1Mayor/box3.jpg//[/IMG]
[IMG]httphttp://i37.photobucket.com/albums/e99/1Mayor/box9.jpg://[/IMG]
__________________
Old 03-10-2007, 10:19 AM   #19 (permalink)
Mayor's Avatar
What you can only post two pictures at a time????
__________________
Old 03-12-2007, 01:46 PM   #20 (permalink)
Gold Member
That looks really nice - great job Mayor!
Scott
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
