Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > John Deere > John Deere Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 03-15-2007, 07:51 PM   #1 (permalink)
Member
savageayape's Avatar
Default 3 point hitch noise on 3520
I've noticed my three point hitch is making a loud noise when I raise it sometimes but only when it's under stress. It makes a loud whinning noise (sometimes) when I have a few hundred pounds on it and raise it. It makes me wonder if there is a problem with the flow of the hydraulic fluid. The reason I mention this is because I noticed it first when my power beyond was hooked up to my log splitter improperly. The fluid was not able to return to the tractor. I immediately shut it down when I heard the noise and found the problem. The connection was not good with the hoses quick connect. Everything works very well, but it makes a noise especially when it's near the top height of the 3pth. The noise is not very noticeable when I have the rpms higher. I've checked the fluid level and it's fine. I checked it when cold and hot. The manual indicates it should be checked when cold. That's what I'm going with and it's fine. Is there something wrong?
savageayape is offline   Reply With Quote
Old 03-15-2007, 09:13 PM   #2 (permalink)
KB9UDE's Avatar
Send a message via Yahoo to KB9UDE
Default Re: 3 point hitch noise on 3520
Do you have a power beyond kit??
John
__________________
John Deere 4120 Power Reverser, 400x Loader-73"HD bucket
John Deere 2320, 200cx Loader-61" bucket
Simplicity SUNSTAR, MMM, Hyd. front blade
Snapper ZF2500KH zero turn
Acts 2:38
KB9UDE is offline   Reply With Quote
Old 03-15-2007, 11:01 PM   #3 (permalink)
New Member
I just bought a used 2006 3720 a couple of weeks ago I have noticed to same type of sounds as you. I too have checked the fluid levels everything looks good, but it sounds bad when lifting a small load.
JPJUDGE is offline   Reply With Quote
Old 03-15-2007, 11:36 PM   #4 (permalink)
Member
Yes, I had the power beyond kit attached by the dealer before I picked up the tractor.
Old 03-15-2007, 11:49 PM   #5 (permalink)
New Member
I have the same noise you describe on my 4600. I've been told this is normal sound caused by hydraulic flow through the power beyond loop.
jrschremser is offline   Reply With Quote
Old 03-16-2007, 01:05 AM   #6 (permalink)
JC-jetro's Avatar
If you exceed the relief pressure setting on main pump discharge then the relief valve will discharge hyd oil back to reservoir and causes the screeching noise or chatter. One other possibility can be the mis-adjustment of the feed back arm to 3 pt lift handle spool valve that could cause dead heading the pump prematurely and relief valve activation to protect the pump. It most likely is some fluid blockage past (on discharge side) of hyd pump.
JC-jetro is offline   Reply With Quote
Old 03-16-2007, 07:50 AM   #7 (permalink)
KB9UDE's Avatar
Quote:
I have a 3320 with power beyond and experience the same thing. The dealer says this is normal with this option. He said there is an extra filter and something else that makes the noise.
John
__________________
Acts 2:38
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
