#1 (permalink) |
Well , if you own a 46 backhoe. you know what crummy feet are on the stablizers
there small and just 4 little spikes. and thay have only minimal lift. and pavement work is out of the question . why JD dropped the ball on this i will never know . after a very long search to see if anyone made a flippad for dirt and street for the 46 hoe . I found very little. and what i did find , i figured i could do it better..( and i did )... Big thanks go's to Brett6284D for sending me detail pictures of his 448 foot , so i would have a pattern. and i went to work. this was quite a job to figure all the geometry for it to work perfect. 46 and 448 leg is different. and i could not use just plain steel it would soon fatige and bend. so i finally located some very i tensel steel. man was this hard to cut and work. i bought a set of 448 street pads. and thats what i built them off of. There monsters.... I changed the geometry a bit. as you will see. tractor lifts like a 3720 with a 448 now. quite a bit higher than the factory 46 does . with a much larger foot print. and thay flip right over to work in dirt or street. it uses the factory pin and cotter keys. and looks like thay came on the tractor. the way JD should have done it in the first place. and ya it does make the tractor look mean , and gives it some subtance. and much more stable on slops. thay were expencive and time consumeing to make but i felt it was needed and worth it. Your probebly saying. Well Do Thay Work???Yes , i already tested them on concreat and dirt. and thay exceeded my expectations. I am pleased. You look and tell me if you think thay work well. Johnny D can get some air now..... Chris... ![]()
__________________
John Deere 2520 , R4's , 200CX loader with 61 inch bucket and JD Tooth Bar. And Markham 7 tooth. Tooth bar. 46 Backhoe with 16 inch bucket. with Custom made Street Flip pads off a 448 hoe. Foward work lights. Dual rear work lights. Heavy duty Alternator. I-Match , Ballast Box , Frontier BB2060 box blade , Frontier pallet Forks , JD 3 point reciever hitch. and soon A lot more.. and for grass cutting , John Deere GX 255 with 48 inch deck.
#2 (permalink) |
Very nice work. JC
__________________
JD 3320 LX5, KK rake and off brand box and rear blade. Millonzi grapple. Deere X495 for grass cutting. 01 Ram 4x4 2500 CTD and 22' 12k trailer. Want a tiller and dump trailer. |
#5 (permalink) | |
Banned
Quote:
If you want to sell another pair, allow me to be your first customer - PM me anytime |
#6 (permalink) |
Epic Contributor
And for those who will wonder, yes, I removed several posts from this thread. Let's please remember to keep things civil, and if you don't like something someone else posts, please notify the moderators instead of attacking the person whose post you didn't like.
__________________
#7 (permalink) | |
Quote:
I surly was not my intention to cause trouble i was only trying to help those that wanted help. Chris
__________________
#8 (permalink) | |
Banned
Quote:
I find, as do others find this type of thread extremely helpful. Lots of 2320 & 2520 with 46BH owners out there who are scratching their heads as to why Deere offered a one-dimensional footpad. Not enough pictures on the subject as it stands.....nice work Chris2520!! |
#9 (permalink) |
Thanks Duc....
I appreciate that. I just wanted everyone with the 46 hoeto know there is a Solution to the problem. its alot of work. but it can be done. Right now there is only one set in the world... I will order another set of the 448 Street pads . and try to get started on yours , later next week. then there will be 2 ... Chris.... ![]()
__________________
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
