JD348 Wire Baler--problem with the twister hooks
JD348 Wire Baler--problem with the twister hooks. (Sorry I don't see how to start my own thread).
I'm using RedBrand wire (all that is sold around here).
The wire keeps getting stuck in the crevice of the hooks and won't pull out. Sometimes I get a build-up of wire there. Then the wires/bales start breaking. I had it working pretty well by the end of last year. Started this year (same wire, stored inside). After 2 rows, the wire gets stuck now on every bale--every bale breaks. I ended up having an assistant walk alongside the baler to signal me every time it tied a bale so we could stop and pull (yank with long needle-nose pliers, pry, swear) the twisted wire off the hooks. The right side is definitely worse that the left side. I replaced these hooks a few years ago, with no improvement. Trying to finish the field today with no assistant to watch ...I might as well be forking the hay by hand! Is it better to have a worn out hook--so maybe the wire won't bind up in the crevice? Note bales are slightly shorter on the right side, but not banana-shaped.
