TwinWillows
Gold Member
Thought I'd start a thread on our experience(s) getting a square baler for our farm.
Background: We've been doing small square bales for the past 4 years on about 10 acres of grass/clover pasture. We tried shared baling - either 2/3 - 1/3 or 1/2 - 1/2 but did not end up w/enough hay for our horses. We changed to custom baling the past couple years but w/such small acreage have trouble getting anyone to come back the next year -which I understand if they are loosing $'s.
This year I just can't seem to get the baling put together - a combination of small acreage not generating enough hay to make it profitable for custom work & farmers not wanting to spend time haying when they are so behind getting their row crops in due to the extremely wet spring..
So this year I've been trying to approach it differently..
a) Trying to find a new custom man (no luck so far)
b) custom but try splitting the cutting & raking apart from the baling. Which generates more coordination & headaches. (marginal luck w/this one)
c) Try to find a small baler I can run on our tractor (NH TC40DA) and still custom cutting & raking until we can get some of that equipment..
I know my tractor HP is not enough to run a newer baler but I've been following zzvyb6's posts on running a JD14T behind his so I've been looking for an older baler along the lines of JD 14 or 24 T or NH 273.. So far the ones I've seen have been in pretty poor shape or too far away.
This weekend getting bees for our new hives (another new adventure), I noticed a JD green square baler back in the shop. A long story short it's a JD 24T square baler. He has not used it in @ least 3 years, the last time he ran it it sheared off a bolt that drives the pickup (? don't know my terms yet) so he parked it & has had a neighbor do his hay work since then.
It's missing some guards & but everything else looks like it's there. When he shut it down he cleaned out the last hay so the chamber is not rusted like a lot of them I've seen.
We're going back tomorrow to pick it up & haul home to try & fix up & put to work (this year hopefully)..
I think this will be an interesting experience getting this running & learning about balers - I know nothing about how a hay baler works - but hopefully this will make our haying operation work better.. I've already bought an operators manual online..
I'll post photos & probably lot's of questions as this unfolds.
Twin
Twin
