Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1
    Member
    Join Date
    Nov 2010
    Posts
    40
    4020 John Deere tractor
    Default 4640 tractor
    I have a 4640 john Deere tractor and after running for about an hour all the hydralics shut down, I changed out all filters and cleaned the screen in bottom of trans. The screen was almost stopped up but clean now, still does same thing when hot after it cools down it starts moving again could it be in main pump or trans pump has anybody ran into this problem before?
  2. #2
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,901
    South West MI
    John Deere 2030, John Deere 6415
    Default Re: 4640 tractor
    I'd lean towards the main pump. Something getting hot and sticking maybe?
    Trans pump is a pretty simple gear pump.
    It may take more than one filter cange, and screen cleaning to clear things up?
    How old is the fluid? Correct level?
  3. #3
    Member
    Join Date
    Nov 2010
    Posts
    40
    Default
    The fluid in it now has been changed to new. I was thinking to remove filters again and screen to double check there , I was thinking if problem still accurs that it may be main pump to .
  4. #4
    Member
    Join Date
    Nov 2010
    Posts
    40
    Default
    I was wondering if it was in trans pump would it start moving again after it cools down or would it just not move when that one goes out, reason I ask because it is affecting steering and all lifts not just trans
  5. #5
    Join Date
    Aug 2010
    Posts
    3,901
    South West MI
    Tran pump is so named because it is in the trans. The trans is the reservior and it pumps to the main pump suction side. Main pump feeds all hydraulics, steering, 3pt (rockshaft), and SCVs
  6. #6
    Member
    Join Date
    Nov 2010
    Posts
    40
    Default
    Thanks for the info
  7. #7
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    It would be good to know how hot the hydraulic oil is when you are having this problem. The reservoir capacity is small considering the flow rate capacity. You may have cooling issues or excessive wear on the pump but there are a few things to consider before pulling the pump. I think that it isn't as likely to be a restriction in the lines or filters as you say it works fine when cool.
    The transmission pump (gear type) is pumping IIRC whenever the engine is running and the clutch is engaged. Don't know how it bypasses when the main pump is out of stroke (no hydraulic functions being operated) and full pressure is reached. Will have to check the drawings to see.
    If it is similar to the 4020 the priority valve shifts at pressures below 1900 psi to steering and brakes only, so does the rockshaft work at startup then it fails shortly before the steering fails?
    Do you have a pressure guage to check the system pressures cold and hot?
    I would also add there is a filter above the drain plug on the bottom of the pump that is about the size of a shotgun shell that I had fail on my 4020, for a 4640 this is part # R27173 on the stroke control assembly. This is easy to check and get to from the bottom of the tractor, remove the drain plug assembly which has a small rod with this filter on it. This small filter screen if plugged up will shut down the pump. If you look at the stroke control in Deere parts it is marked as #17.
  8. #8
    Join Date
    Dec 2010
    Posts
    505
    Does the reservoir, up by the fuel tank run dry when you run out of hydraulic? That would be a mark in favor of a weak trans. pump or a high volume leak downstream. Does this unit have a high/low on the trans?
  9. #9
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    When you say after it cools it will start moving again are you referring to the drive train?
  10. #10
    Member
    Join Date
    Nov 2010
    Posts
    40
    Default
    Everything with hydralics starts working again
Similar Threads
  1. parts manual for JD Tractor 4640
    By bti611 in forum John Deere Buying/Pricing
    Last Post: 05-03-2009, 12:54 AM
  2. JD 4000 series wheel bolts
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-13-2002, 10:56 AM
  3. What's your SPI?
    By 8NTX in forum Related Topics
    Last Post: 03-27-2002, 01:46 PM
  4. John Deere, how did you make my tractor?
    By JohnMiller3 in forum John Deere Owning/Operating
    Last Post: 07-29-2001, 04:23 PM
  5. Hills: Forwards or Backwards?
    By glennmac in forum Kubota Owning/Operating
    Last Post: 09-05-2000, 01:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
