Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Aug 2010
    Posts
    10
    John Deere 2355,820 (3 cylinder), 2150, Farmall a, Allas Chalmers G,
    Default 4440 sn# breaks
    I have a 1978 4440 and they say the first year had 86mm axles. But also the cabs and some other stuff is different. But I can't figure out what is different. Can anyone help me. Also how to u get the front cab mounts out
    Thanks. Hugh
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,238
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: 4440 sn# breaks
    Quote Originally Posted by Hughlofting View Post
    Thanks. Hugh
    Frt SGB(cab) mounts(part # R111173) can be removed by unscrewing screw (part # R54745 SELF-LOCKING SCREW 3/4" x 4") from bottom of the mount.
    I'm relatively sure that 4440's only had 92 MM axles,4240 had 86 MM axles. 4430 had the axle change from 86 to 92 MM at SN 040770.
  3. #3
    New Member
    Join Date
    Aug 2010
    Posts
    10
    Default
    I was told early 4440s had 86 mm axles and a. 4430 cab. I need to go measure I guess
  4. #4
    Join Date
    Jan 2007
    Posts
    7,238
    Coyote Flats,Tx
    SGB's didn't change a lot from 30 through 55 series. Interior colors,radio speakers and outside door handles is all that comes to mind. 86MM axles aren't listed for a 4440 in the parts catalog.
  5. #5
    New Member
    Join Date
    Aug 2010
    Posts
    10
    Default
    Ok thanks. All I saw was SN# breaks in the parts for the cab early and late but I don't know what's different
  6. #6
    Join Date
    Jan 2007
    Posts
    7,238
    Coyote Flats,Tx
    There is no SN break on the body in pc # 1898 only SN break I found is on these parts
    R50449 PANEL 1 SN - 272636 X X X L.H.
    R51704 PANEL 1 SN - 272636 X X X R.H.
    JD also offers a SOUND-GARD BODY FOR REPLACEMENT which is for total replacement in case of an accident.
  7. #7
    New Member
    Join Date
    Aug 2010
    Posts
    10
    Default
    Thanks again Jim. I just love my 4440 and I want to learn as much as I can about it
Similar Threads
  1. ?date mf 243 with sn?
    By Soundguy in forum Massey Ferguson Owning/Operating
    Last Post: 07-10-2009, 12:00 AM
  2. Kama 454, "grindy" breaks
    By Paddy in forum Chinese Tractors
    Last Post: 07-26-2007, 10:27 PM
  3. Tax breaks for small farmers?
    By dooleysm in forum Owning/Operating
    Last Post: 08-21-2005, 10:19 PM
  4. HELP..rear wheel breaks off!
    By ejb in forum John Deere Owning/Operating
    Last Post: 06-20-2000, 10:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
