Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    May 2011
    Posts
    1
    john deere6400
    Default 6400 trans noise in 1,2,3 powershift
    does any body know if there is a common planatary set or shaft for those three gears in a 6400 tranny with a right hand reverser? shift it to forth and rattle goes away. Has any one ever experianced this problemb befor.
  2. #2
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,803
    South West MI
    John Deere 2030, John Deere 6415
    Default Re: 6400 trans noise in 1,2,3 powershift
    It has a compound planetary which reduces input rpm for 1st 2nd and 3rd. 4th is direct drive rpm wise.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  3. #3
    New Member
    Join Date
    Jul 2011
    Posts
    13
    melbourne australia
    front snap ring wears in trans you can get all diff sizes if that not tight trans will rattle. prob best check out before gets worse worse can break bolts in packs
Similar Threads
  1. Replies: 111
    Last Post: 10-04-2003, 12:37 PM
  2. popping noise after start up
    By jb112454 in forum Kioti Owning/Operating
    Last Post: 02-16-2002, 06:46 AM
  3. Noise from motor I think
    By jgreyt in forum New Holland Owning/Operating
    Last Post: 07-09-2001, 12:57 PM
  4. B2400 4WD noise
    By JimM in forum Kubota Owning/Operating
    Last Post: 06-25-2001, 04:41 PM
  5. Boomer - Trans. noise ?
    By marty in forum New Holland Owning/Operating
    Last Post: 07-11-2000, 01:01 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
