Results 1 to 10 of 12
04-24-2012, 10:12 AM #1Member
- Join Date
- Nov 2010
- Posts
- 40
- Tractor
- 4020 John Deere tractor
4010 hydralics
We were driving this tractor down the road and all the sudden the shredder dropped and steering quit . Checked fluid and it's full but now hydraulics . Someone said it could be the pump . Anything else that could be checked first? $$$$
04-24-2012, 10:38 AM #2Silver Member
- Join Date
- Jan 2012
- Posts
- 236
- Location
- Winchester Ky
- Tractor
- Allis Chalmers ED 40
Re: 4010 hydralics
Can you hear the pump turning when the engine is running? Check the drive coupler from crank pully to pump shaft. Sounds like maybe the pump stopped turning.
04-25-2012, 08:25 AM #3Veteran Member
- Join Date
- Jan 2007
- Posts
- 1,914
- Location
- Coyote Flats,Tx
- Tractor
- JD 4255/Kubota M7040 HDC
Re: 4010 hydralics
I'll second checking frt hyd pump drive coupler. The coupler has been known to get loose on pump shaft and not turn pump. If 3pt or scv powered impl. dropped when pump quit then that hyd function has leaking valves.
04-25-2012, 09:26 AM #4Super Member
- Join Date
- Feb 2008
- Posts
- 7,738
- Location
- somewhere usa
- Tractor
- stuff
04-28-2012, 11:07 AM #5
We've had this happen before and my guess is that its the stroke control valve. They stick sometimes and the dealer should have a tool that will take care of the problem. If it was the pump coupler it would have made a nocking noise long before it went out.
04-29-2012, 08:59 AM #6Veteran Member
- Join Date
- Jan 2007
- Posts
- 1,914
- Location
- Coyote Flats,Tx
- Tractor
04-29-2012, 11:09 AM #7
"Tool" can mean many things to a Farmer.
04-29-2012, 03:20 PM #8Platinum Member
- Join Date
- Feb 2012
- Posts
- 593
- Location
- Summit. Ms
- Tractor
- JD 4840, 450j, 310, komatsu D31, IH 1486, MF 135
You need a de-stroke vavle like tx jim said. Get one. Install it on hyd pump, then with engine running, screw it all the way in then back out. Should fix it.
Your tractor may already have one installed. They are fairly common. Look on top of the hyd pump for a little T handled screw theaded into a nut @ the front of the pump.
04-29-2012, 07:03 PM #9
Yea good job texas Jim for coming up with that stroke control valve idea......wait...what??
04-30-2012, 08:36 AM #10Veteran Member
- Join Date
- Jan 2007
- Posts
- 1,914
- Location
- Coyote Flats,Tx
- Tractor
Similar Threads
4010 Power Beyond
By bobsphotos in forum John Deere Owning/OperatingReplies: 3Last Post: 11-13-2010, 08:14 PM -
4010 ?
By wilnis in forum John Deere Buying/PricingReplies: 3Last Post: 06-20-2007, 09:52 PM -
2210 or 4010
By Koz in forum John Deere Buying/PricingReplies: 24Last Post: 03-28-2004, 07:11 AM -
When can I get a 4010?
By JonLeonard in forum John Deere Buying/PricingReplies: 3Last Post: 05-12-2002, 10:05 PM -
Buying Advice 4010 negotiating advice
By hazmat in forum John Deere Buying/PricingReplies: 12Last Post: 05-10-2002, 07:51 AM
