Results 1 to 4 of 4
06-23-2012, 11:00 PM #1New Member
- Join Date
- Jun 2012
- Posts
- 2
- Location
- Michigan
- Tractor
- Jd 8640 white 2-135 case 2470 IH 1466 and some others
JD 8640 hydraulic problems
hey guys need some help i have an 8640 that lost all hydraulics i have checked the two screens on the back half they were clean and the coupler from the engine to pump is good i have no steering or remotes
thanks Errol
06-24-2012, 07:17 PM #2Platinum Member
- Join Date
- Apr 2004
- Posts
- 615
Re: JD 8640 hydraulic problems
If equipped with a pto, does it work? Is the trans hydraulic circuit maintaining 165psi? Could be a failed trans pump or trans pump drive. On occasion the pressure relief or the plugged filter divert valve will stick with a wee bit of dirt or a broken spring. No oil from the transmission hydraulics pumped up to the front pump inlet means no high pressure hydraulics.
06-24-2012, 11:22 PM #3New Member
- Join Date
- Jun 2012
- Posts
- 2
- Location
- Michigan
- Tractor
pto works. i will check thoues out 2marrow thanks
06-25-2012, 08:55 AM #4Veteran Member
- Join Date
- Jan 2007
- Posts
- 1,921
- Location
- Coyote Flats,Tx
- Tractor
- JD 4255/Kubota M7040 HDC
Non functioning stroke control valve in main hyd pump will stop hyds from working
Similar Threads
John Deere 8640 Repair Manual
By mbdias in forum John Deere Ag TractorsReplies: 10Last Post: 03-02-2012, 09:32 AM -
Hydraulic problems
By theboman in forum Parts/RepairsReplies: 2Last Post: 09-13-2009, 10:21 AM -
Hydraulic problems
By EMail4U in forum HydraulicsReplies: 15Last Post: 10-02-2004, 08:10 PM -
Hydraulic Problems
By toddwulf in forum New Holland Owning/OperatingReplies: 2Last Post: 01-01-2002, 09:29 PM -
JD 9400 & JD 8640
By Anonymous Poster in forum John Deere Owning/OperatingReplies: 0Last Post: 10-06-2001, 12:46 AM
