Results 1 to 5 of 5
07-03-2012, 04:50 PM #1Member
- Join Date
- Nov 2010
- Posts
- 40
- Tractor
- 4020 John Deere tractor
1050 john deere diesel
I've been working on this tractor and have checked injector timing and looks good and checked compression 380 to 420 psi not sure what compression should be but tractor starts up and blows a lot of black smoke and starts idling faster and faster on its own. It will not shut down with lever you have to break injector lines to shut down has anybody had this problem. It's eating my lunch.
07-03-2012, 04:56 PM #2
Re: 1050 john deere diesel
The compression is ok its in spec so as long as all 3 are that close to equal once the pump problem is solved she should run nice. No haven't had and problems but it sure sounds like its the pump to me try the Yanmar forum also this is a Yanmar tractor/engine.
Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me.
"Hey you didn't build that."
07-03-2012, 05:08 PM #3Member
- Join Date
- Nov 2010
- Posts
- 40
- Tractor
Thanks I appreciate the help I will try that forum
07-03-2012, 05:28 PM #4
07-05-2012, 11:07 PM #5New Member
- Join Date
- Feb 2012
- Posts
- 18
- Location
- Everson, wa
- Tractor
- 5105m
Replace injectors i had a 990 that would run away like that. Also use a board over air intake to kill engine. Cracking injectors while running is dangerous.
Similar Threads
John Deere 1050
By mbrunelli in forum John Deere Owning/OperatingReplies: 5Last Post: 12-10-2011, 07:23 PM -
John Deere 1050
By wilsonfam in forum Private Party AdsReplies: 2Last Post: 09-22-2011, 11:55 AM -
John Deere 1050
By wilsonfam in forum John Deere Owning/OperatingReplies: 0Last Post: 09-20-2011, 05:31 AM -
John Deere 1050
By KubotaMan7 in forum John Deere Owning/OperatingReplies: 2Last Post: 06-22-2005, 12:35 PM -
John Deere 1050
By grnthumb in forum John Deere Buying/PricingReplies: 10Last Post: 01-16-2005, 08:17 AM
