Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. #1
    New Member Daveb50's Avatar
    Join Date
    Oct 2012
    Posts
    16
    Pa
    John Deere b
    Default 1951 John Deere B with a jd 50 power block
    Looking for any help that may be out there. We put a jd 50 power block into our b this summer. Now we are trying to get the bugs worked out. We have an issue with it cutting out. The governer asks for more fuel and the tractor falls on its face. Tryed adjusting the linkages and nothing seems to help. Last night I removed the linkage from the side of carb. Started the tractor and by hand opened up the butterfly on the carb. Didn't even reach half way open and it fell off. Any idea?
  2. #2
    Super Member
    Join Date
    Apr 2004
    Posts
    6,497
    East Coast of Lake Huron
    Deere, several
    Default Re: 1951 John Deere B with a jd 50 power block
    Leaning out due to extra airflow.
  3. #3
    Join Date
    Oct 2012
    Posts
    16
    Pa
    John Deere b
    So you think it has to much air? The spark plugs are black sewty looking
  4. #4
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    Default
    Quote Originally Posted by Daveb50
    Defiatly not the correct mixture. They should be a beigh color. The black junk on the plug is reffered to as a fowled plug.
  5. #5
    Join Date
    Oct 2012
    Posts
    16
    Pa
    John Deere b
    Ok thank you. I know it has two screws on each side of the double barrel carb. So I will try to get the mixture right. Thanks again
  6. #6
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    Quote Originally Posted by Daveb50 View Post
    Do you have a manual with the initial adjustments on the carb?
  7. #7
    Join Date
    Oct 2012
    Posts
    16
    Pa
    John Deere b
    Well it's a jd 60 carb. I believe the manual says 1 1/4 turns for a 50 and 2 1/2 turns for a 60
  8. #8
    Join Date
    Oct 2012
    Posts
    16
    Pa
    John Deere b
    But in my thinking I believe that it should be less than 1 1/4 turn. Because the carb is jetted for a 60. The reason we are using this carb is we were told we needed it for more fuel for the power block. Any ideas?
  9. #9
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    With the carb for the 60 it will be jetted bigger. This is allowing the fuel that would go into the bigger engine on the 60 to go into the one on the 50 flooding it and causing your problem. With the carb set properly it will work. If it idles fine to about 1/4 throttle then dies when revved higher it is most likely the main jet that is plugged. Also check your choke that is is not disconnected leaving the buttery valve to float freely.
  10. #10
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,625
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    i agree with mike r.. especially after hearing about the plugs.
Similar Threads
  1. john deere power drive 21
    By chazdo2 in forum John Deere Lawn & Garden
    Last Post: 06-01-2012, 10:44 PM
  2. John Deere Power beyond
    By rjslota in forum John Deere Owning/Operating
    Last Post: 03-22-2011, 06:04 PM
  3. Power Beyond for John Deere 4300?
    By reasley in forum Hydraulics
    Last Post: 11-16-2007, 03:37 PM
  4. John Deere 755 Engine/long/short block needeed
    By Charlie_Iliff in forum Parts/Repairs
    Last Post: 10-24-2006, 12:58 PM
  5. john deere power????????
    By whitearrow in forum John Deere Buying/Pricing
    Last Post: 08-17-2005, 02:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
