Results 1 to 8 of 8
11-06-2012, 03:43 PM #1New Member
- Join Date
- Oct 2012
- Posts
- 7
- Location
- MO
- Tractor
- 3020 John Deere
john deere 3020 slow starting
I have a 1965 gas 3020 that turns over slow to start unless I turn the steering wheel left and right then it turns over at regular speed. Any ideas of how to fix it?
11-06-2012, 03:53 PM #2Veteran Member
- Join Date
- Jan 2007
- Posts
- 2,066
- Location
- Coyote Flats,Tx
- Tractor
- JD 4255/Kubota M7040 HDC
Re: john deere 3020 slow starting
Install a destroking screw in the main hyd pump.
11-06-2012, 06:31 PM #3New Member
- Join Date
- Oct 2012
- Posts
- 7
- Location
- MO
- Tractor
- 3020 John Deere
Would you have a drawing of the location of the destroking screw location? I would appreciate it
11-07-2012, 07:47 AM #4Veteran Member
- Join Date
- Jan 2007
- Posts
- 2,066
- Location
- Coyote Flats,Tx
- Tractor
Parts key #6(AR33249) if hyd pump hasn't been replaced with one with a serial number.
11-07-2012, 08:36 AM #5New Member
- Join Date
- Oct 2012
- Posts
- 7
- Location
- MO
- Tractor
- 3020 John Deere
Thanks, I should be able to remove it without pulling the pan.
11-07-2012, 02:57 PM #6Veteran Member
- Join Date
- Jan 2007
- Posts
- 2,066
- Location
- Coyote Flats,Tx
- Tractor
Just remove the screen in front of the radiator on LH side and there is the plug.
11-08-2012, 08:02 AM #7New Member
- Join Date
- Oct 2012
- Posts
- 7
- Location
- MO
- Tractor
- 3020 John Deere
Thanks, I will get with Dealer today and get one or get it on order.
11-09-2012, 12:54 PM #8New Member
- Join Date
- Oct 2012
- Posts
- 7
- Location
- MO
- Tractor
- 3020 John Deere
Put it in and it starts fast now. Dealer said the propane starter would do better.
Similar Threads
John Deere 3020 turbo
By JaredWardall in forum John Deere Ag TractorsReplies: 3Last Post: 04-21-2012, 11:36 PM -
John deere 3020 maintnance
By JaredWardall in forum John Deere Ag TractorsReplies: 6Last Post: 04-10-2012, 01:23 PM -
Buying Advice John Deere 3020
By bmcqueen23 in forum John Deere Buying/PricingReplies: 20Last Post: 08-15-2011, 04:36 PM -
Buying Advice John Deere 3020 or 720
By wmaburnett in forum John Deere Buying/PricingReplies: 2Last Post: 07-24-2011, 09:33 AM -
John Deere 3020
By Cowboy in forum John Deere Buying/PricingReplies: 2Last Post: 08-23-2000, 08:47 PM
