Results 1 to 5 of 5
11-25-2012, 03:05 PM #1New Member
- Join Date
- Aug 2012
- Posts
- 3
- Location
- Lafayette LA
- Tractor
- John Deere 1050
11-25-2012, 06:05 PM #2Veteran Member
- Join Date
- Jan 2007
- Posts
- 1,892
- Location
- Coyote Flats,Tx
- Tractor
- JD 4255/Kubota M7040 HDC
Re: JD 1050
6' should be fine depending on how many "gators" are laying the driveway.
11-25-2012, 08:09 PM #3New Member
- Join Date
- Aug 2012
- Posts
- 3
- Location
- Lafayette LA
- Tractor
- John Deere 1050
11-25-2012, 10:47 PM #4Veteran Member
- Join Date
- Dec 2009
- Posts
- 1,616
- Location
- S. W. Virginia
- Tractor
- Kubota B3200, Ford NAA, Deere 5203
Re: JD 1050
The width of the box blade depends on how you are going to be using it. For heavy work such as excavating, heavy grading and moving large amounts of soil the 5' unit would work better. For light work like grading the driveway, small leveling projects, etc a 6' would probably be ok. You just don't have the weight or traction to pull a 6' in a heavy cut with the rippers down. I agree on the 5' bush hog as well.
Kubota B3200
Ford NAA Jubilee
Deere 5203
11-25-2012, 10:53 PM #5New Member
- Join Date
- Aug 2012
- Posts
- 3
- Location
- Lafayette LA
- Tractor
- John Deere 1050
Re: JD 1050
Thanks for the replies. They also have a 4' BB for sale (used) for a good price. The tractor tires would be quite a bit wider then the BB so not sure if that would be worth it.
Similar Threads
JD 1050 Value
By TC33DA in forum John Deere Buying/PricingReplies: 6Last Post: 05-15-2010, 02:36 AM -
JD 1050
By jgbanshee in forum John Deere Owning/OperatingReplies: 3Last Post: 01-25-2009, 12:11 PM -
JD 1050
By jgbanshee in forum John Deere Buying/PricingReplies: 3Last Post: 04-20-2008, 10:40 PM -
1050, what to look out for?
By qstott in forum John Deere Buying/PricingReplies: 6Last Post: 01-15-2006, 10:48 PM -
JD 1050
By rstrickland in forum John Deere Buying/PricingReplies: 3Last Post: 09-23-2005, 04:02 PM
