Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Jan 2013
    Posts
    2
    Dunseith, ND
    6420 JD/640 JD loader
    Default 6420/640JD loader joystick won't operate
    The tractor & loader has only 800 hrs. And the joystick will not operate I'm stumped please help
  2. #2
    Elite Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Kubota 9540, RTV 900 and David Brown 885.
    Default
    Quote Originally Posted by Carmen View Post
    If it "will not operate" as in "joystick will not move" you have moisture frozen in the cables or some other problem with the cables.
  3. #3
    Join Date
    Oct 2008
    Posts
    1,071
    Piedmont Triad, NC
    Didn't intend to have a Deere fleet - it just happened 310C, F915,102 & 5200
    Smile Re: 6420/640JD loader joystick won't operate
    Simple question... Is the lock lever in the operate position? It's located low on column that holds the joystick.
    It's easy to bump to lock ...
  4. #4
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Default
    Quote Originally Posted by hosspuller View Post
    I thought about that but gave the guy a little credit.
  5. #5
    New Member
    Join Date
    Jan 2013
    Posts
    2
    Dunseith, ND
    Default Re: 6420/640JD loader joystick won't operate
    Quote Originally Posted by DT86 View Post
    This joystick is ,electronic not manual. The stick is in the console.
  6. #6
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Default
    I see. Sounds like you need to check fuses and possibly call a dealer.
  7. #7
    Platinum Member Edward. S's Avatar
    Join Date
    Nov 2009
    Posts
    844
    Somewhere
    John Deere
    Do you put your hand in the little cradle thing? Do you put your hand in there?
    http://salesmanual.deere.com/sales/s...r_joystick.jpg
    If you don't the loader will not work.
    If not, its something electrical.
Similar Threads
  1. 300CX Loader Joystick
    By pane056 in forum John Deere Owning/Operating
    Last Post: 10-01-2012, 08:24 AM
  2. Loader Ford 1710 loader only operate with 3 point in raised position
    By mauser1111 in forum New Holland Owning/Operating
    Last Post: 03-13-2011, 08:55 AM
  3. joystick hard to operate on Jinma 754
    By billrickey in forum Chinese Tractors
    Last Post: 08-20-2009, 01:50 AM
  4. End loader joystick
    By dodge man in forum Kubota Owning/Operating
    Last Post: 01-23-2009, 12:17 PM
  5. loader joystick
    By Anonymous Poster in forum Kubota Buying/Pricing
    Last Post: 05-24-2001, 11:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
