Results 1 to 6 of 6
01-28-2013, 01:33 PM #1New Member
- Join Date
- May 2011
- Posts
- 9
- Tractor
- JD 7400, 5410, Kubota B8200
5410 Transmission Problem
My 5410 has 7,400 hours and a new Woods 6' FEL. I bought it from a dealer & am supposedly the second owner. The gasket at the split underneath the tractor between the front and rear of the tractor, approximately under the seat, deteriorated after 10 hours of loading chicken litter & had to be replaced invovling splitting the tractor. Then while driving fast in C range, it chewed up gear teeth in the transmission top shaft and the A range gear. Has anybody heard of 5410's having problems with loader work or faulty transmissions? Appreciate the help.
01-28-2013, 01:36 PM #2Veteran Member
- Join Date
- Dec 2010
- Posts
- 1,643
- Location
- SW VA
- Tractor
- David Brown 885, Kubota RTV 900, Kubota 9540
That is the first I've heard but then again I only know of a handful with that many hours.
Treat me good and I'll treat you better, treat me bad and I'll treat you worse.
01-28-2013, 03:23 PM #3New Member
- Join Date
- May 2011
- Posts
- 9
- Tractor
Re: 5410 Transmission Problem
Gald to hear it. If they are notorious for trans problems, others would know. Hopefully not a sign of more trouble to come. Thanks.
01-28-2013, 10:13 PM #4Platinum Member
- Join Date
- Apr 2011
- Posts
- 620
- Tractor
- cx70,5510,4630,5005
recon the trans fluid ran out and you ran the top of the transmission dry.
01-28-2013, 10:16 PM #5
If you have power reverser, make sure to stop the tractor with the brakes to a complete stop before putting into park. There have been some people who put it into park while the tractor is still moving and shear off the park pawl. $$$
You can put a gold saddle on a donkey but it's still a donkey.
01-29-2013, 08:16 AM #6New Member
- Join Date
- May 2011
- Posts
- 9
- Tractor
I do use the brakes to stop before putting in park. I also let the tractor stop moving when shifting from forward or reverse before completing the shift into the opposite direction. Probably do not have too but I prefer to take it easy on the trans. The previous owner may not have. However, it chewed the teeth while I was operating the tractor at a fast travel speed and approximately 2000 rpms. The mechanic isn't sure why it did it. Thanks.
Similar Threads
Transmission problem?
By taroblaro in forum 2-Wheeled TractorsReplies: 5Last Post: 03-19-2012, 10:47 PM -
transmission problem
By sharpanther in forum Parts/RepairsReplies: 0Last Post: 08-26-2011, 10:22 PM -
Oil & Fuel Transmission problem
By sharpanther in forum Mitsubishi/SatohReplies: 0Last Post: 08-24-2011, 03:22 AM -
Mowing Transmission problem
By OhioGuy in forum Cub Cadet Yanmar & CUTsReplies: 17Last Post: 06-28-2011, 06:45 PM -
Need Help on Transmission Problem
By bill747 in forum Parts/RepairsReplies: 5Last Post: 04-02-2004, 06:19 PM
