Results 1 to 7 of 7
  1. #1
    Gold Member 2006gmcdmax's Avatar
    Join Date
    Aug 2012
    Posts
    285
    Augusta, GA
    Many but mostly ford diesels or ihc or jds
    Default John deere 300 lift issues
    I have a John deere 300 industrial. The lift is strong but slow. The guy I bought it from put new springs on the rock shaft and all the fluids and filters. Could it need a new pump or is there a valve somewhere that may be stuck open? He said something about a valve that you have to split the tractor to get too is this true he said it maybe stuck open.
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,053
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: John deere 300 lift issues
    I bet the problem is the orange filter in the photo Seriously I wonder if PO checked/cleaned trans/hyd sump screen and small filter in frt hyd pump?? I also recommend checking stand-by pressure(2250-2350 psi). It's possible the hyd filter relief valve could be the problem. Does tractor have the option of hyd hi-lo or reverser??
    Attached Thumbnails Attached Thumbnails John deere 300 lift issues-t60044_________un01jan94-gif
  3. #3
    Join Date
    Aug 2012
    Posts
    285
    Augusta, GA
    I have no clue if it has hi and lo or reverser but he said he changed all the fluids and filters he wants 3000 for it only reason I'm buying I never knew there was a screen on the front hydro pump either
  4. #4
    Join Date
    Aug 2012
    Posts
    285
    Augusta, GA
    I talked to the guy no reverser or hi an lo on hydros he change one screen on the tranny and the hydro filter the hydro filter on the front he did no change and he put new seals on the rock shaft and replaced some springs
  5. #5
    Join Date
    Jan 2007
    Posts
    7,053
    Coyote Flats,Tx
    That's a nice looking industrial tractor. Depending on tractor SN hyd pump filter is parts key # 56 in 1st photo or parts key #17 in 2nd photo.
    Attached Thumbnails Attached Thumbnails John deere 300 lift issues-rp3314_________un01jan94-gif   John deere 300 lift issues-rp3510_________un01jan94-gif
  6. #6
    Join Date
    Aug 2012
    Posts
    285
    Augusta, GA
    Yeah I thought it was a very nice looking tractor I want it for my business or my business I'm starting it would he perfect for my box blade and ok thank you ill try that do these have adjustments on the rock shafts he said something about that too
  7. #7
    Join Date
    Jan 2007
    Posts
    7,053
    Coyote Flats,Tx
    The RS control valve seals on JD utility tractors have a history of wearing out then leaking causing hyd problems. If PO renewed o-rings everything in there should be fine. BUT for grins remove hyd filler cap on the rear and with 3 pt raised,engine running look inside hole for spraying oil. No spraying oil then the RS control valve should be GOOD.
Similar Threads
  1. john deere 300
    By JohnDeere300 in forum John Deere Lawn & Garden
    Last Post: 01-25-2013, 07:48 PM
  2. John deere 300
    Last Post: 01-24-2013, 09:38 AM
  3. john deere 300 loader backhoe
    By pago52 in forum Hydraulics
    Last Post: 04-21-2012, 12:23 PM
  4. John Deere 300 Backhoe
    By nitetrain9 in forum John Deere Vintage Tractors
    Last Post: 04-08-2012, 09:15 AM
  5. John Deere X 300.
    By Tugalert in forum John Deere Lawn & Garden
    Last Post: 05-06-2009, 05:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
