Results 1 to 2 of 2
  1. #1
    Join Date
    Mar 2008
    Posts
    249
    Ohio
    NHTN95, Ford 4000, John Deere and one Case
    Default 6330 lower link arm operation question
    I just got a new 6330 and yes I know I need to post photos to prove it at some point. For now, bear with me please. I was looking through the manual and the options for draft control, the settings, etc. are numerous to to say the least. Can someone give me brief tutorial on what really works for you. For me, I generally need to raise the links and lower them. I do know I can control the speed at which the arms raise and lower. Other than that, what features are really of benefit. The manual talks about locking the arms to prevent pitching when transporting attachments.
  2. #2
    Join Date
    Dec 2012
    Posts
    56
    Western NC
    green
    Default
    Keep the draft links bunjee corded together when not hooked on to an implement. Having them swinging around can damage your tires or the load Sensor that operates the draft control. I use it when plowing sometimes but not always. Otherwise you have a rate of drop dial and a height control dial to the rear of the control. Use the rate of drop to keep implements from crashing down. I don't really use height control except for w a big long 3 pt harrow w baskets. I keep it as close to the ground as practical in case I pop a wheelie on steep headlands. Or at least ill set it like that when training new operators. Best of luck. Great tractor.
    JD 5085M *JD 6110 w 640 loader *JD 6330 *AC F2 Gleaner * Ford 7.3 PSD x 2
Similar Threads
  1. 3-Point Hitch Lower Link Arm Adjustment
    By Skintback in forum Kubota Owning/Operating
    Last Post: 11-20-2012, 07:03 PM
  2. 3-Point Hitch New Holland 1715 lower lift arm question
    By bucknbass in forum New Holland Owning/Operating
    Last Post: 07-28-2011, 12:00 AM
  3. bent lower link lift arm
    By tcreeley in forum New Holland Ag Tractors
    Last Post: 06-11-2011, 08:15 PM
  4. Jinma 354 LE vertical link for lift arm Question
    By GuglioLS in forum Chinese Tractors
    Last Post: 02-14-2005, 11:10 PM
  5. Broken lower arm link- bad metal?
    By DiskDoctr in forum Mahindra Owning/Operating
    Last Post: 07-09-2004, 03:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
