Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,082
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: 3020
    Quote Originally Posted by pjbci View Post
    AGRIMAN, i thougt everybody knew the JD steering wheel trick till a few weeks ago. A farmer freind of mine called to ask if there were any tricks to cranking my 4840 he had borrowed. At first i told him no then ask him, you are spinning the steering wheel arent you? He had never heard of such. Anyway it cranked right up then.
    The steering wheel trick doesn't help starting as much on later models tractor because of the change in the type steering valve to the metering pump type steering. This change happened about mid production on the 30 series(4230/4430/4630). My 4255 will start fine in sub-freezing temps without the steering wheel trick,ether or block heater.
  2. #12
    Platinum Member pjbci's Avatar
    Join Date
    Feb 2012
    Posts
    712
    Summit. Ms
    JD 4840, 450j, 310, komatsu D31px22, IH 1486, MF 135, MHF TO35
    Default
    It helps on every rowcrop 40 series i have ever been on.
Similar Threads
  1. 3020
    By garyelliott73 in forum Attachments
    Last Post: 06-11-2011, 10:20 AM
  2. deere 3020
    By deboer in forum John Deere Owning/Operating
    Last Post: 01-17-2010, 01:45 PM
  3. Deere 3020
    By robert23239 in forum John Deere Owning/Operating
    Last Post: 10-02-2009, 12:44 PM
  4. 3020 Hydraulics
    By 3020 JD in forum John Deere Owning/Operating
    Last Post: 08-03-2008, 04:25 PM
  5. IH equivalent of JD 3020
    By bocephus in forum Case-IH
    Last Post: 02-06-2007, 09:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
