Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
  1. #11
    Platinum Member pjbci's Avatar
    Join Date
    Feb 2012
    Posts
    712
    Summit. Ms
    JD 4840, 450j, 310, komatsu D31px22, IH 1486, MF 135, MHF TO35
    Default
    If you have a deere construction equip dealer nearby, they will print you whatever pages you need for testing hyd charge pressure and main pump pressure. These test will be very helpful in diagnosing your problems but im still thinking your main clutch has failed
  2. #12
    Join Date
    Dec 2001
    Posts
    1,351
    Maryland
    Default Re: John Deere 410 backhoe, have to split in two, need help please!!
    The dry clutch and the forward wet clutch can be accessed from the same split at bell housing. The transmission pump and wet reverse clutch need to be accessed from the split between the clutch housing and transmission.
  3. #13
    New Member
    Join Date
    Mar 2013
    Posts
    8
    Alabama
    John Deere 410
    Hey guys,
    Well, since I stared this thread, we took the machine to a shop and had the engine, dry clutch, power steering pump, and radiator replaced. Engine cranks and runs great, hydraulics are good and strong, but the machine will still barely pull itself. It has about two gears that it will pull itself in. It does seem to work fine in reverse, just not forward.
    Any ideas what the issue might be? Wet clutch pack? Hydraulic pump? I'm guessing it's going to take breaking the machine apart again to fix it, right?
    Also, filters are new and we cleaned the transmission sump screen.
    Thanks for ideas and suggestions.
  4. #14
    Join Date
    Dec 2001
    Posts
    1,351
    Maryland
    Sounds like the forward wet clutch pack is slipping. The disks may not be worn out, but seals definitely need renewing. Parts 2, 7, and 9 are the seals. Part #1 is a sleeve the sometimes gets worn from seals #2, so pay close attention to that.
    Attached Thumbnails Attached Thumbnails John Deere 410 backhoe, have to split in two, need help please!!-tp48861________un02nov95-gif
  5. #15
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,800
    South West MI
    John Deere 2030, John Deere 6415
    I agree check forward clutch, since reverse is OK
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  6. #16
    New Member
    Join Date
    Feb 2012
    Posts
    7
    Victoria
    John Deere X595, M
    Unhappy Re: John Deere 410 backhoe, have to split in two, need help please!!
    Quote Originally Posted by cowboybkr View Post
    Hey guys,
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    Have you been able to resolve your problems on the JD410? If not please respond and I will give you a few tips that may assist without splitting the tractor.
  7. #17
    New Member
    Join Date
    Oct 2014
    Posts
    1
    shell knob, mo
    JD 410B
    I need a wiring diagram for a John Deere 410-B backhoe. The wiring in this backhoe has been tampered with so much that they aren't hooked up properly. The meters don't work and the lights aren't hooked up. Wires are dangling everywhere on this tractor.
    The backhoe starter turns over the engine like it has a dead battery. The batteries are new. I think it might be the solenoid or the ignition switch. I need to know what it could be so I can repair it. Thank You!
  8. #18
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,162
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    If battery ground cable is attached to battery box relocate cable to starter mounting bolt. Sorry but I can't help you with wiring diagram.
  9. #19
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,734
    Murray, KY
    1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
    Some one did a post on replacing the O rings in the forward clutch pack. It top gear at fast idle (1000 RPM?) when you move shuttle to go forward or backwards it should kill the engine. Our 310B is OK cold but after working it hard it will slip going forward especially in high range which is not a real issue since we just use in around the place most of the time. Racing the engine for 1 second and letting off the fuel will let the front pack clutch lock up in our case. One must NOT operate it if the clutch pack will not lock up. I had to back ours to the house when we first got it but after a couple fluid and filter changes we got most of the water out of it and it did better. I have found adding a gallon of Lucas Hydraulic Oil Booster from time to time helps some all way around.
  10. #20
    Super Member
    Join Date
    Apr 2004
    Posts
    6,726
    East Coast of Lake Huron
    Deere, several
    $350 service manual?
    The tractor is old and has been thrashed or trashed from one end to the other . Cheaper to cut your losses and sell it .
Similar Threads
  1. Front-End Loader John Deere fel 410
    By tomcatoib in forum Attachments
    Last Post: 11-01-2012, 03:40 PM
  2. Priming a 410 John Deer Backhoe
    By dgclover in forum Owning/Operating
    Last Post: 08-12-2012, 02:30 PM
  3. Replies: 8
    Last Post: 07-07-2012, 06:54 PM
  4. Deere 410 loader/backhoe?
    By dntfxr in forum John Deere Owning/Operating
    Last Post: 08-04-2011, 11:34 AM
  5. WHAT ALL WILL THE 410 JOHN DEERE LOADER FIT ???
    By CRACKERJACK69 in forum John Deere Lawn & Garden
    Last Post: 05-09-2010, 11:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
