Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Mar 2012
    Posts
    5
    Lexington
    John Deere
    Default 6603 heat a/c question
    I have a 6603 that I am having issue with the a/c. Tractor has 12xx hours
    I bought the tractor used (auction) and the previous owne, said they had changed the expansion valve and dryer, but did not know of any other service to the a/c system.
    The tractor cools very good at idle, but at higher rpm the system freezes up. I suspected the system to either have air flow issues or be low on refrigerant, but the filters, condenser and evaporator were clean. I hooked gauges up, and to get the low pressure up to anything higher than 20 the high side was 400+ and climbing.
    I am certianly not an a/c expert, but it doesn't follow what I have seen in the past. Could it be an issue where too much oil is in the system causing the high side pressures to run too high.
    Also was using the tractor yesterday, and the outside temp was 45*. I got a little warm in the cab so I turned the heat all the way down, and the just ran the fan thinking the fan would blow cool air from outside, but with the temp turned all the way down, and the fan on (no a/c) the vents were blowing warm air. I could turn the heat up and the it got hotter, but it never blew cool air as I would have expected given the outside temp.
    I am wondering if I have a couple issues.
    Thanks for any help you may have to offer.
    Patrick
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,052
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: 6603 heat a/c question
    I think it either has too much Freon(common problem) or condenser is plugged blocking air flow. Looking clean & really being clean are 2 different things. Down here in sunny Texas if the sun is shining AC needs to work. I've seen some heater water control valves that let enough water pass to affect ac cooling capabilities. My 4255 had the valve leakage problem so I installed manual cut-off valves in the heater hoses.
  3. #3
    Join Date
    Jan 2012
    Posts
    598
    Winchester Ky
    Allis Chalmers ED 40
    An external heater shut off valve is a trick I've used for years to combat a defective valve in the cab, but only one is needed. As for the A/C issue; What exactly, do you mean by "the system freezes up"? You said it cools OK at an idle. If so, what are the pressure readings at that point? If you have doubts about the condensor's effectiveness, get the system running and try using a garden hose to cool down the condensor while watching the gauges. If that drops the high side down considerably(to 250 PSI or less), you need to verify the airflow through the condensor and radiator. One or the other may not be as clean as it looks. If nothing changes, or at least not much, then consider the freon level, oil level, or even the performance of the new expansion valve.
  4. #4
    New Member
    Join Date
    Mar 2012
    Posts
    5
    Lexington
    John Deere
    Thanks guys.
    I can add the cut off. I didn't even think of that, but we have them on both of Dad's tractors.
    I will check again for cleanliness.
    Harry, do you do a/c service? I am in Lexington and don't know a good a/c man
    thanks again for the help
Similar Threads
  1. John Deere 6603 A/C question
    By pnhigg in forum John Deere Ag Tractors
    Last Post: 03-29-2012, 12:14 PM
  2. Heat Pump question...
    By MossflowerWoods in forum Rural Living
    Last Post: 11-15-2011, 11:30 AM
  3. John Deere 6603
    By cwcurry in forum John Deere Buying/Pricing
    Last Post: 06-07-2009, 08:33 PM
  4. 6603 tractors
    By g0705 in forum John Deere Buying/Pricing
    Last Post: 05-24-2008, 11:45 AM
  5. 6403 or a 6603, anybody have one
    By green4710 in forum John Deere Owning/Operating
    Last Post: 04-01-2005, 01:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
