Results 1 to 3 of 3
  1. #1
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,839
    South West MI
    John Deere 2030, John Deere 6415
    Smile Need a measurement from a tractor with Skid Steer Quick Attach on it's loader
    I am going to build an adapter for my loader for skid steer quick attach. I ordered the Quick Tach Conversion Assembly. The measurement I need is; with no bucket/implement on your loader, the loader lowered to the ground, the SSQA mount plate vertical. Distance from the ground to the top edge of the SSQA mount. I need to know what height to build mine to when I attach loader mount to the Conversion Assembly. Thanks in advance.
    Prefer measurement from a full size tractor since that's what this will be used on.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  2. #2
    Elite Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Kubota 9540, RTV 900 and David Brown 885.
    Default
    Mine, while not a Deere but is SSQA, measured 18.5".
  3. #3
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,993
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Default Re: Need a measurement from a tractor with Skid Steer Quick Attach on it's loader
    Quote Originally Posted by Zebrafive View Post
    .......I need to know what height to build mine to when I attach loader mount to the Conversion Assembly. Thanks in advance.
    The height should be low enough to swap attachments on level ground, and the bottom of a level bucket can go a couple inches below ground level.
    Doesn't matter what the machine is, these are all the way down.
    Need a measurement from a tractor with Skid Steer Quick Attach on it's loader-p3070021-jpg
Similar Threads
  1. Skid steer quick attach
    By kuboman in forum Kubota Owning/Operating
    Last Post: 02-16-2011, 10:17 AM
  2. 3 pt to skid steer quick attach.
    By tungularafishcamp in forum Build-It Yourself
    Last Post: 10-03-2010, 12:43 AM
  3. Kubota B21 - skid steer style loader quick attach?
    By nvr-enuf in forum Kubota Owning/Operating
    Last Post: 12-25-2009, 04:13 PM
  4. 430 Quick Attach Bucket to skid steer attach
    By CLinton_in_FL in forum John Deere Owning/Operating
    Last Post: 07-17-2006, 11:57 AM
  5. Skid Steer Quick Hitch or Quick Attach
    By Rolando in forum Kubota Buying/Pricing
    Last Post: 09-02-2004, 09:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
