Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    May 2013
    Posts
    4
    stratford, on
    John Deere 5510, White 140, White 180
    Default 5510 Reverser reacts slow
    My 5510 reacts slowly when I shift from forward to reverse Tractor has 7200 hrs I do not know the service history. The clutch is very touchy too
  2. #2
    Join Date
    Dec 2001
    Posts
    1,353
    Maryland
    Default Re: 5510 Reverser reacts slow
    Since you say you don't know service history, does that mean you recently got this tractor? Have you ever run a reverser before? The reversers do feel a little sluggish when shifting forward to reverse or reverse to forward. It should feel similar when shifting into forward or reverse. If reverse is noticeably more sluggish, then there is probably a pressure leak in the reverse clutch. Is the clutch touchy in forward and reverse both? There are some modulating springs in the control valve that could be broken if clutch is jumpy, or you could have worn or warped clutch disks.
  3. #3
    Join Date
    Apr 2011
    Posts
    746
    cx70,5510,4630,5005
    clean the transmission screen,put a john deere filter on and fill it with the correct fluid then try it.
  4. #4
    New Member
    Join Date
    May 2013
    Posts
    4
    stratford, on
    Thank you for your comments. Yes I recently purchased the tractor. The clutch is touchy in both forward and reverse. The sales man that I bought the tractor from said these tractors have a hydraulic clutch that don't wear out. Guess I should have got a second opinion. The reverse reacts better if I clutch when shifting . If I do nt clutch there is a hesitation. Will change the hydraulic filter and clean the screen.
  5. #5
    New Member
    Join Date
    May 2013
    Posts
    4
    stratford, on
    Thank you I will try that first
  6. #6
    Join Date
    Apr 2011
    Posts
    746
    cx70,5510,4630,5005
    give us a update
  7. #7
    New Member
    Join Date
    May 2013
    Posts
    4
    stratford, on
    I have not got at it yet but will let you know what the results are
Similar Threads
  1. jd 5510 power reverser hesitates when shifted
    By cjl in forum John Deere Ag Tractors
    Last Post: 09-27-2012, 11:17 PM
  2. 5510 Clutch
    By mitchash in forum John Deere Owning/Operating
    Last Post: 07-31-2008, 11:19 PM
  3. Sync Reverser vs. Power Reverser- Is there a difference
    By blaplante in forum John Deere Buying/Pricing
    Last Post: 09-05-2007, 08:48 PM
  4. 53,54, or 5510?
    By poorboy in forum John Deere Buying/Pricing
    Last Post: 03-03-2001, 08:48 PM
  5. 5510 or 6210
    By Vernon in forum John Deere Buying/Pricing
    Last Post: 07-24-2000, 03:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
