Results 1 to 5 of 5
  1. #1
    Join Date
    Aug 2005
    Posts
    117
    philadelphia,ms
    john deere 5203
    Default JD 5203 hour meter not working
    good morning fellas. i have a 2005 JD 5203 ag tractor that just recently,as in today, the hour meter stopped working. when i started working today the hour meter showed 60.1 hours. after approx. 4 hrs of bushogging the hour meter showed 60.2 hrs. what would happen for a hour meter to go out with as little hours as my machine has? before starting my work i did splash the instrument panel with some water to clean it off as i don't have access to running water at my place. could that have screwed something up? i did notice it kinda frosted up a lil around the hour meter after the splash of water. what all could i check and exactly where to see whats happening with the hour meter? is there a fuse for it? everything else works just fine i.e. tach,fuel guage, and warning lights.
    thanks,
    Eddie
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,167
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: JD 5203 hour meter not working
    Check to see if speed sensor on the frt of engine has the wires connected properly
    Attached Thumbnails Attached Thumbnails JD 5203 hour meter not working-cd39018________un01jan94-gif
  3. #3
    Join Date
    Aug 2005
    Posts
    117
    philadelphia,ms
    john deere 5203
    Thanks Jim. Is that on the left side close to the front of the engine? How should they be correctly connected?
    Thanks,
    Eddie
  4. #4
    Join Date
    Jan 2007
    Posts
    7,167
    Coyote Flats,Tx
    My knowledge is limited on your tractor model but I'm fairly confident that speed sensor should have 2 wires connected. Speed sensor is located on LH frt of engine.
  5. #5
    Silver Member Varmint1's Avatar
    Join Date
    Jun 2012
    Posts
    175
    Deville,La
    JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
    Default
    The instrument cluster in the 5000 series tractor are prone to just go out, just changes one in a 5083e because the tach wouldn't work
Similar Threads
  1. L2800 hour meter not working
    By KD93 in forum Kubota Owning/Operating
    Last Post: 12-15-2013, 02:36 PM
  2. Tachometer and hour meter not working
    By RMJ22 in forum John Deere Ag Tractors
    Last Post: 02-16-2012, 08:38 AM
  3. hour meter not working
    By natem in forum Kioti Owning/Operating
    Last Post: 12-03-2007, 07:01 PM
  4. hour meter not working
    By andystix in forum Parts/Repairs
    Last Post: 02-25-2004, 09:52 PM
  5. Hour Meter Stopped Working
    By MikePA in forum New Holland Owning/Operating
    Last Post: 11-22-2003, 01:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
