Tractor Beam
- Joined
- Feb 10, 2010
- Messages
- 151
I step on the right brake, the tractor turns easily and is silent. However, when I step on the left brake, there is a seriously ugly growling noise in the rear end and I mean it's loud and gritty. My first thought since the planetary gear set, bearings and shaft are totally new, is that the noise is coming from the spider gears? Puzzled though because if it was a loose of damaged spider gear, it would make the noise from either brake being applied. Also seems to make noise when going fast as in high gear and maximum engine RPMs and you just come to a stop going straight. No noise slowing down but just as the tractor stops there's a short burst of loud growl. I'm snowed bad guys. What to do. Tractors parked until I figure it out but it's snowing right now.
