Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    New Member
    Join Date
    Jun 2011
    Posts
    9
    Fort Kent, Maine
    JD 2955 MWFD & JD 3020 Diesel
    Default 2955's Topless Now Questions
    Hey guys we've got my 2955's cab off to fix a broken shifting linkage and we're thinking of replacing the clutch since its the original and I'm at 4600 hrs and we've found that the hand brake is all burnt to sh** so I have to change that out too. My questions are:
    For the clutch what needs to be changed out? JD parts lists to different clutch disks; AL70272 & AL69935, plus the clutch itself AL68485. The throw-out bearing is AL120028.
    For changing out the hand brake band can we wiggle that out as-is without pulling apart the left planetary?
    Anything else we should check while we have it apart this far?
  2. #2
    Join Date
    Dec 2001
    Posts
    1,356
    Maryland
    Default Re: 2955's Topless Now Questions
    The clutch disk is kind of personal preference. The AL70272 is the factory style and is considered "heavy duty". The AL69935 is "regular duty". Personally, I like the regular duty. It is smoother operating, less jerky in operation. WIth a good operator, it lasts just as long and it is less aggressive on the pressure plate and flywheel surfaces. I would plan on sending the flywheel to machine shop to be resurfaced. Also plan to replace the pilot bearing. Part number JD10107. If you choose the heavy duty clutch, there is a part number that includes the disk and pressure plate in one box. AL64948 is a "kit" that includes AL70272 and AL68485 in one box. The kit saves you a few bucks.
    The brake band can only be changed after removing the left final drive. A pin needs to be removed that is only accessible from the left final drive area. Even then it can be a pain in the butt, but while cab is off it would be foolish not to replace it. Hopefully the drum that the brake rides in is not destroyed. That requires removing both final drives and differential to replace.
    Personally, I would replace orings and seals in rockshaft(three point) valve while it is off. Pretty easy to do and costs only a few dollars in parts.
    What did you find in the shift linkage?
  3. #3
    New Member
    Join Date
    Jun 2011
    Posts
    9
    Fort Kent, Maine
    2955's Topless Now Questions-cm_0038-jpg
    That's AL55218… $365 dollar piece of tin.
    Strange on the clutches… AL70272 is cheaper than AL69935.
  4. #4
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,233
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Here's clutch & PP from A&I plus they also offer pilot & TO brgs
    Attached Thumbnails Attached Thumbnails 2955's Topless Now Questions-capture-jpg
  5. #5
    Join Date
    Jan 2007
    Posts
    7,233
    Coyote Flats,Tx
    Quote Originally Posted by North Maine View Post
    A
    Where did you get a price of $365 for AL55218? Here's my dealers price: AL55218 Shaft ADD 458.89 USD
  6. #6
    Join Date
    Dec 2001
    Posts
    1,356
    Maryland
    True on clutch disk prices. I assume they make more heavy duty than regular duty and therefore can make them less expensively.
  7. #7
    Super Star Member Kyle_in_Tex's Avatar
    Join Date
    Oct 2002
    Posts
    11,144
    Giddings, Texas
    JD 4310,JD5420
    My buddy had to split his 3155 because of the hydraulic pump that feeds the main pump. If yours has that, I would recommend changing it. Symptoms are that your steering and hydraulics get weak when fluid gets hot.
    One of these days....One of these days...
  8. #8
    New Member
    Join Date
    Jun 2011
    Posts
    9
    Fort Kent, Maine
    Quote Originally Posted by Tx Jim View Post
    A
    Thank you AMAZON!!
  9. #9
    New Member
    Join Date
    Jun 2011
    Posts
    9
    Fort Kent, Maine
    Quote Originally Posted by Kyle_in_Tex View Post
    I think its a similar system (if not identical) on the 2955. I was worried that one might be an issue later.
  10. #10
    Join Date
    Dec 2001
    Posts
    1,356
    Maryland
    The 2955 does have the same transmission pump setup. I can't say I would recommend replacing it if you have no symptoms. Those pumps are pretty reliable. The pressure line from that pump has been known to break though. If you decide to make the extra split(between clutch housing and transmission) be sure to check the pressure pipe and elbow at the pump. There has been an upgraded line, fitting and clamp that takes the stress off of the line that was causing it to fail. Not sure, but all the 55 series may have the better line. I think the 50 series were the ones with problems in that area.
Similar Threads
  1. Replies: 3
    Last Post: 09-10-2012, 11:06 PM
  2. More general questions and some 1985 B7200 questions
    By Code54 in forum Kubota Owning/Operating
    Last Post: 08-08-2012, 08:44 PM
  3. Got a little topless time in today.
    By Topkicker in forum Trailers & Transportation
    Last Post: 08-28-2011, 11:21 PM
  4. Starting a hobby farm. Questions Questions!
    By PapaPerk in forum Projects
    Last Post: 03-05-2011, 01:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
