Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Apr 2014
    Posts
    1
    Georgetown, Texas
    Default john deere 1050 1985 model
    I want to change the hydralic fluid. Never done this before. I have new fluid and new filter.
    Is this done same as with oil change, just drain fluid and change fiter?
    Any other steps?
    (No loader on tractor, just three point hitch)
  2. #2
    Join Date
    Jul 2000
    Posts
    225
    Western,MA
    JD 850, L130, 317
    Default Re: john deere 1050 1985 model
    That's pretty much it but there may be more than one drain plug for the transmission and rear end. Have a large enough container it holds about 6 gallons of oil.
  3. #3
    Member
    Join Date
    Jan 2013
    Posts
    37
    plainfield ct
    850 jd
    The other step you want to do is to clean the suction screen. It runs cross wise across the tranny on the bottom. It is a triangle shaped cover on the left side just in front of rear wheels. Take cover and pull out the fine mesh screen in there. Clean it with some brakeclean or equiv., dry off and reinstall then good to go. The suction screen prevents any metal or large debris from going into the pump.
  4. #4
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,056
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Here's a parts photo of the screen.
    Attached Thumbnails Attached Thumbnails john deere 1050 1985 model-rp1425_________un02jan94-gif
Similar Threads
  1. 1985 John Deere 318 with mower, tiller & snowblower
    By rpowers in forum Private Party Ads
    Last Post: 05-14-2014, 03:33 AM
  2. 1985 John Deere 116H
    By Maxify55 in forum John Deere Lawn & Garden
    Last Post: 02-16-2014, 07:45 PM
  3. 1985 JOHN DEERE 216
    By rjackson1138 in forum John Deere Owning/Operating
    Last Post: 09-20-2010, 03:15 PM
  4. 1985 JOHN DEERE 216
    By rjackson1138 in forum New Member Introductions
  5. 1985 JD 1050 w/75 loader SHUDDER
    By BrianJD1050 in forum Hydraulics
    Last Post: 11-26-2008, 07:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
