cantbeatadeere
Hey Guy's, my three point will settle from full up to the ground within a couple hrs. with no load on it. I have honed the cyl. and replaced the o-ring on the rockshaft piston and it still settled, removed the return valve and checked the spring/valve and all looks mint. the Tech-manual says under the "excessive settling" section to check for weak or broken return spring(looks perfect), return valve leaking(also looks perfect), pressure metering shaft wear(again.. perfect), rockshaft piston O-rings(new)..........Now for the million dollar question.-- is the relief valve and the "thermal" relief valve one in the same?? and what check valve would they be talking about. those are the last couple things to check and I cant find either one in the manual under the rockshaft section..............any input would be great. thanks
