imabass
I have the 3020 with the double bevel rims. Currently I have it set to the inside bevel and I can simply move the cast center to the outside bevel and narrow the rear wheels by a total of 8".
My question is adjusting the cast centers. From what I gathered, I loosen the 6 bolts (3 inside and 3 outside) then use the nut mounted at 90* to drive the cam along the pinon that is machined in the axle. My guess is that is easier said than done given that wheel has not moved along that shaft in 50 years.
I measured my wheels and from outside to outside I am 104" wide. I am needing to get a trailer to move the tractor and I would like to narrow the rears to safely get on/off the trailer. Based on my measurements, I should be able to narrow up to 16" and still have sufficient clearance on the 3 point lift. There will also be added benefit of being able to take tighter turns when pulling a trailer or brush hog.
Thanks!
Thanks!
