Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Jul 2016
    Posts
    22
    France
    Someca 35
    Default 3040 JD hydraulic oil leak Help needed.
    I have a John Deere 3040 tractor that is losing a lot of oil from a cylindrical tank above the oil cooler and radiator. The previous owner simply put a hose into a drum to collect the oil and reused it.
    The cylindrical tank has a banjo connection on the top that the oil is coming from. It is connected to the suction side of the hydraulic pump driven from the front of the engine.
    I was wondering if the tank contains an expansion balloon that has burst. I simply have no idea what the problem is and what to do to cure it.
    Thank you for any replies.
    Humphrey
    ps I think it is the transmission header tank.
  2. #2
    Join Date
    May 2014
    Posts
    838
    Paarl South Africa
    Default Re: 3040 JD hydraulic oil leak Help needed.
    expansion balloon .....no ! Oil comes from the main seal in the mainhydraulicpump to the top off the tank and then back to the gearshiftcover. That "bolt" ontop of the tank has a oneway checkvalve that prevents oil from entering that small tube . Check that valve !
  3. #3
    New Member
    Join Date
    Jul 2016
    Posts
    22
    France
    Someca 35
    I will do that tomorrow and thank you for your help. We tried to undo it but thought it might shear off.
  4. #4
    New Member
    Join Date
    Jul 2016
    Posts
    22
    France
    Someca 35
    Seems that the pipe that should have returned to the gearshift cover was broken off and never re-connected. It took 40 litres of oil to refill.
Similar Threads
  1. TC -29 hydraulic oil leak
    By brin in forum New Holland Owning/Operating
    Last Post: 07-03-2010, 08:56 PM
  2. Oil & Fuel CK30 oil leak help needed
    By Jerek in forum Kioti Owning/Operating
    Last Post: 06-21-2009, 09:33 AM
  3. Hydraulic oil leak??
    By vtkubota in forum Owning/Operating
    Last Post: 02-16-2007, 01:58 PM
  4. Hydraulic oil leak??
    By vtkubota in forum Hydraulics
  5. 3040 Hydraulic Leak
    By Woodsman30350 in forum Montana
    Last Post: 09-12-2006, 08:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
