Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Sep 2016
    Posts
    3
    Godfrey
    2011 5085 M
    Default 5085 M power reverser plus
    Hello All I have a problem with the hi lo split of the forward gears, tractor is in low range and will not toggle up to hi range in any gear. Pretty sure its electrical as worked fine then just stopped. I can not figure which fuse is for hi lo split. Also not sure if any codes are present as not sure how to make it display codes? Thanks
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,975
    Southern Wisconsin, USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Default Re: 5085 M power reverser plus
    jandp
    to TBN
    Hang tight, and help will be along. Other's may know right off, but I cannot help. Sorry...
    A good investment, IMO, is getting a copy of the service tech manual for your 5085.
  3. #3
    Join Date
    Dec 2013
    Posts
    158
    Notasulga, Alabama
    Kubota M7060
    Quote Originally Posted by jandp View Post
    I have an m but not the 24 speed. Typically I would suspect the solenoid that does the shift, wherever it may be. See if power gets there then work backwards.
  4. #4
    Join Date
    Dec 2001
    Posts
    1,363
    Maryland
    The solenoids for high and low are behind the cab on top of the transmission case. There is a valve body just in front of the rockshaft. On the left side of the valve body are 4 solenoids. The 2 toward the front operate the hi-lo. There are no fuses in the circuit. The switch sends voltage to the transmission control unit and then the controller sends voltage to the appropriate solenoid. Be sure to check the k24 relay, it is in the high circuit.
  5. #5
    New Member
    Join Date
    Sep 2016
    Posts
    3
    Godfrey
    2011 5085 M
    Thank you everyone, I have been checking wires seems the hi low switch is ok, but i don't have power on the red wire going to the switch, changed the k24 relay,I am thinking that i have a broken wire between the fuse block and the switch. I am thinking the red wire should have power when the controler is in forward??
  6. #6
    New Member
    Join Date
    Sep 2016
    Posts
    3
    Godfrey
    2011 5085 M
    Ok, so found that the red wire is broken down inside the inner fender,anyone know how to get the right plastic inner fender out thanks.
  7. #7
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Would it be easier to pull in a new wire with the older one? Might be easier than removing the inner fender.
Similar Threads
  1. Power Reverser
    By firels1 in forum John Deere Ag Tractors
    Last Post: 03-03-2015, 09:28 AM
  2. Power Reverser Use
    By MWRR in forum John Deere Owning/Operating
    Last Post: 03-05-2012, 02:48 AM
  3. Sync Reverser vs. Power Reverser- Is there a difference
    By blaplante in forum John Deere Buying/Pricing
    Last Post: 09-05-2007, 08:48 PM
  4. Use of Power Reverser
    By robison in forum John Deere Owning/Operating
    Last Post: 05-01-2005, 05:23 AM
  5. Power Reverser
    By cowboydoc in forum John Deere Owning/Operating
    Last Post: 03-18-2002, 10:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
