JD 5425N
   / JD 5425N #1
DLTTrekkers
Paarl South Africa
Not starting and blows a fuse when in neutral
Found the problem at the neutralswitch.
I had to get a new switch , but that switch was to long. Had to cut the plastic off the new switch and solder the old switch s wires to the new switch. 1477663582846.jpg1477663597144.jpg
   / JD 5425N
This switch is under the seat on the inside of the gearselectorhousing that needs to be removed to do the replacement
   / JD 5425N #3
Sounds like they sold you the wrong switch, but you made it work, so all is well.
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
HOMEMADE 4' X 12' SINGLE AXLE TRAILER (A51248)
HOMEMADE 4' X 12'...
12 in Small Excavator Bucket (A52377)
12 in Small...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
