bigblock76
- Joined
- May 4, 2013
- Messages
- 96
- Location
- Little Britain, Ontario
- Tractor
- John Deere 2120, John Deere 3140, John Deere 2950, John Deere 7700 Combine, John Deere STX38
Is there an adjustment for the front tires to change the angle of how the sit perpendicular to the ground? A camber adjustment to have the tires when driving straight to be bang on perpendicular to the ground. I'm not talking about tie-rod adjustment to change the toe in or out.
I ask because the tire lugs on the inside of each of the front tires are considerably worn compared to the outside lugs. Mind you, it looks like the rims of the front tires were mounted inside out at some point to change the poisition of the tires on the tractor. I'm not sure why they did this but I can see the markings on the rim that they have been turned around at some point. Not sure if that was the cause.
I can take pictures in the morning.
Any feedback appreciated.
Mark
Mark
