1astronautfarmer
Member
- Joined
- Sep 24, 2009
- Messages
- 28
- Location
- Fairfield, Maine
- Tractor
- John Deere 2350 MFWD, John Deere 2355 MFWD, John Deere 420C with Braden winch
Hello
1st I want to say that this forum is a wealth of good info for us that want to try to better understand our tractors and do some/most of the repairs and maintenance ourselves. Applause to the members who try to help us and answer our questions.
I have owned a 2350 MFWD for about 20 years. The tractor has about 5100 hrs. It is an 8F and 4R ,no hi/lo, no reverser tractor. It has a 245 loader.
I just purchased a 2355 MFWD with 9300 hrs 8F and 4R, no hi/lo, no reverser with a 245 loader.
My question or query is that at idle in neutral the transmission/differential in the 2355 seems to be a bit more noisy/rumble than the tranny in the 2350. It sounds like my neighbor's Case/IH tractor of the same approx. HP/size. All the gears are quiet, shifts well, there was nothing in the trans oil when I changed it and ran it through a filter to look for anything out of the norm. Not even discolored. Its almost like the difference between angle cut gear and straight cut gear noise. I didn't know if maybe John Deere may have changed a tranny manufacturer between the 2350 and 2355 models. Anyway....it just has a little more of a rumble in it than the 2350 does and I was wondering if anyone could shed some light on the subject. It would be much less expensive to break it open now for bearings and seals than to replace hard parts down the road.
Second question...on both 245 loaders there is a hydraulic splitter on the right mast that is tied into the bucket roll lines. Why the bucket roll lines and not the lift lines too? Or why is it necessary to have it at all? Also a vent line exits this unit and returns into the transmission.
Thank you all for your valuable input.
