Ok so being frugal (sometimes I wonder if that is a synonym for stupid) I've started on replacing my clutch. Have gotten all the interferences taken care of except 2 well maybe 3.......
Wiring harness pulled forward, too much crap up front to pull it backwards....
Fuel lines pulled back and taped to fender handle....
Hydraulic lines for loader pulled, don't have the magic stands for removing the loader so it's still on. Helpful hint for folks who are also missing them wood isn't strong enough.....
Front drive shaft cotter pin is out but it doesn't want to slide on the splines for removal....hoping that when I roll the back end back it will take care of itself...if not suggestions would be welcome????
Small left hand side hydraulic hard line split.
Right hand side, can't get the hydraulic pressure line to open, assume that the larger hex is the one that is supposed to spin, can't seem to get enough leverage.......advice please????
Right hand side hydraulic suction line free at front but doesn't want to disengage at the back.....advice please???
Thanks,
Jim
Thanks,
Jim
