Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,240
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: 2004 5520 FEL squeals.
    Quote Originally Posted by beenthere View Post
    Fluid isn't close to that "filler" hole (hopefully!).
    I will guess at full mark on dipstick that hyd fluid is 8''-10''+ below hyd filler opening.
  2. #12
    Veteran Member RPW's Avatar
    Join Date
    Aug 2009
    Posts
    1,037
    Thanks, will be working on that after I troubleshoot my AC. Did talk to our local JD dealer and the parts guy pulled up the diagram of the system and suggested I also check the rubber coupler on the intake of the hydraulic pump saying that he's seen either the hoes clamps can come loose or their could be a small crack that's allowing air to be sucked in.
    2008 JD 5103, FEL, 6' Frontier, 6' HD boxblade, 7' Landscape rake, More impliments to come, Bobcat (clark) 742 SS.
  3. #13
    Join Date
    Aug 2009
    Posts
    1,037
    Well this last weekend I checked the sump screen and it was ok. I did notice that I do have some minor leaking at the loader quick connects. I need to use the tractor this week so tighten up those hoses will have to wait until this coming weekend.
Similar Threads
  1. 2004 Mahindra 2015 Gear, FEL 258 Hours $5.8k
    By knukey in forum Mahindra Buying/Pricing
    Last Post: 10-09-2013, 02:28 AM
  2. 5520 FEL control stick binding
    By cvray in forum Mahindra Owning/Operating
    Last Post: 08-02-2010, 04:25 PM
  3. 2004 M6800 w/fel whats it worth?
    By inseeme in forum Kubota Buying/Pricing
    Last Post: 08-04-2006, 09:56 AM
  4. 2004 HST L3130 with FEL 150 hours with 72"FEL
    By widmn in forum Kubota Buying/Pricing
    Last Post: 01-15-2005, 08:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
