Results 1 to 4 of 4
  1. #1
    Member
    Join Date
    Feb 2010
    Posts
    29
    Rosenberg, TX
    Kubota L2350, L3800, L3710; JD 5425, 6105R, 7130-P; IH 1086
    Default JD 6105 rear panel removal seems impossible
    In my 6105, there is an interior panel behind the seat that I need to remove. I am stumped - I cannot remove it.
    Two lower screws are out and the panel can pull out (tilt up) at the bottom, but the top seems like it could be designed like a barb - push in to catch, but can't pull out. Even expecting this, it is very tight and I can't get one edge started to see if my concept is correct:
    JD 6105 rear panel removal seems impossible-parts-rear-panel-behind-seat
    Has anyone removed this panel? The JD Repair manual does not explain how. Can you provide me with a tip?
  2. #2
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,901
    South West MI
    John Deere 2030, John Deere 6415
    Default Re: JD 6105 rear panel removal seems impossible
    Maybe your dealer has that panel in stock in parts and seeing it would tell you how it comes out???
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  3. #3
    Join Date
    Dec 2001
    Posts
    1,363
    Maryland
    Walk around to the back of the tractor with the window open. in the black frame you should find some screws with phillips heads I believe. I think there are only 2. The screw from outside and screw into the upholstery panel.
  4. #4
    Member
    Join Date
    Feb 2010
    Posts
    29
    Rosenberg, TX
    Quote Originally Posted by jd110 View Post
    Will do. I have seen the two screws you mention and thought the plastic extended down behind the SCVs and had other fasteners, so for some reason dismissed that as an option, believing I should not have to bother with the exterior for an interior part. Great tip.
Similar Threads
  1. NAA Instrument Panel Removal
    By OrtisEvans in forum Ford Vintage Tractors
    Last Post: 04-01-2018, 08:29 PM
  2. Replies: 0
    Last Post: 11-28-2017, 11:23 AM
  3. engine side and front panel removal
    By Ken P in forum Kubota Owning/Operating
    Last Post: 07-10-2011, 08:42 AM
  4. Ford 3000 Body Panel Removal
    By scouse lee in forum Ford Vintage Tractors
    Last Post: 02-28-2011, 08:50 PM
  5. b7300 instrument panel removal
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 11-21-2001, 04:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
