Re: Why Doesn\'t Deere Sell Boxblades?
I had the same grievance with my 513,the best thing I can suggest is do like I did,go to your local welder and mark out some 3/8" stock to match the sides and back of the cutter and weld to the cutter reinforce this area on the cutter.Now if you have a cutting torch and can weld the only thing you would have any $$$ is the 3/8" stock.Mine is vastly superior to what it was after I 1st bought it.I think the gearbox is adequate,its just the thin metal they use to build these things.
