Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    Gold Member CWP37's Avatar
    Join Date
    Nov 2005
    Posts
    275
    Hill Country, TX
    John Deere 5103 w/ 512 LDR
    Default 2008 5203 4WD Price ans Compare
    Here we go again. I've about sold my 5103 and looking for 4WD. I called three dealers to look for 3 quotes. Got one back today:
    5203 4WD w/ 522 Loader
    -R4 tires
    -Horizontal rear exhaust
    -Hood guard
    -iMatch
    -2nd rear SCV
    -Rear work light x2
    -Tool box (fender mount)
    -73 " heavy duty bucket
    -Skid steer carrier
    -72" tooth bar
    -Skid steer bale spear
    $27,250 delivered
    New machine, anybody else have any pricing to compare?
    For that price, what 4x20 can I get with the same options?
    Thanks in advance.
    Chip
  2. #2
    Join Date
    Jan 2007
    Posts
    1,706
    Central-western UP Michigan
    Kioti DK5010HS
    Default Re: 2008 5203 4WD Price ans Compare
    I paid about $26k for a 5105, which did not include a 2nd rear SCV, skid steer QA, rear lights, toolbox, bale spear, or tooth bar. I will hazard a guess that the value of those items is in the neighborhood of $1250.
    Based on my experience you would get a 4120 gear for around $24k without the extras (but with 400X FEL). Figure an extra $1000 for HST and $1500 for each 5hp bump in power (4320, 4520, 4720). Unless you want/need HST I think the 5203 will be more tractor with less stuff to break.
    Incidentally, do you want the rear exhaust? Where does it come out - will it be blowing on you when changing implements? I consider the upright exhaust stack to be a plus.
  3. #3
    Join Date
    Nov 2005
    Posts
    275
    Hill Country, TX
    I like the horizontal exhaust because I mow in/around/under a lot of trees. Most of my place is flat and I can put the ROPS down and get a "prettier" cut.
    I got quote #2: $27,301 for the same package.
    Chip
  4. #4
    Join Date
    Nov 2005
    Posts
    275
    Hill Country, TX
    I figured a 4120 HST or 4320 gear would be close to the same price.
    I really like the stability and size of the 03 series, though.
    I think I'd have to find a 4520/400CX/Gear with the same options for the same price to really make me consider the 4X20 series.
    Chip
  5. #5
    Join Date
    Jan 2007
    Posts
    1,706
    Kioti DK5010HS
    Why bother looking at the 4x20? It seems you liked your 5103 except for being 2wd. The 5203 MFWD will fix that and give you a couple other nice upgrades, and should be just as durable as the 5103. I think the 4x20 are good tractors but they are CUTs and I expect the utility models to keep running twice as long and be far harder to break.
  6. #6
    Elite Member RollingsFarms's Avatar
    Join Date
    Mar 2007
    Posts
    2,539
    South Carolina
    Few John Deere's and one Ford 3600 diesel.
    Chip, have you considered a 4WD 5103?
  7. #7
    Join Date
    Nov 2005
    Posts
    275
    Hill Country, TX
    Yes, but the pto hp on the new 5103 is a little slim, I think 38 hp vs. 45 hp for the new 5203. I've used every bit of hp on my current 5103 with all this rain we've had this year.
    Just don't want to bog down my shredder.
    Chip
  8. #8
    Member
    Join Date
    Aug 2007
    Posts
    32
    Prague OK
    Kioti DK35
    i got a quote of $29150 for:
    2008
    5403
    4x4
    522 loader
    remotes
    horizontal exh
    9x3 sync trans
    rear work lights
  9. #9
    Join Date
    Mar 2007
    Posts
    2,539
    South Carolina
    Quote Originally Posted by CWP37
    i know what you mean. i am sort of in the same situation as you. if the new 5103 had the same hp as they used to i would probably get one with 4wd, but will either get a 5203, or a used 5105/5205. im just not sure how well 38pto hp would run a medium duty 6' bush hog in thick stuff. is the 522 loader the quick attatch? how do you think those R4's will do with all the rain yall have had compared to an R1?
  10. #10
    Join Date
    Jan 2007
    Posts
    1,706
    Kioti DK5010HS
    522 loader is a quick attach/detach from the tractor. Only the 512 is a permanently mounted loader. (All JD loaders have a quick attach for the bucket.)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
