Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Default 5210
    I was getting very close to purchasing a 4710 w/loader for $22,000. The unit has only 10 hrs on it. I then came across a 2001 5210 4x4 w/541 loader and power reverser trans . The unit has less than 100 hrs. The cost is $22,500. It seems like a lot more tractor for about the same price. Is there any difference with the 4710 vs 5210 power reverser trans has far as operation goes(not up to speed on this trans)
    thanks Ken
  2. #2
    Join Date
    Jan 2002
    Posts
    1,726
    Cambridge, New York
    JD425 lawn tractor; JD4710 CUT; JD JX75 Walk Behind
    Default Re: 5210
    Don't really know much about the PowerReverser trannies since I'm looking more at eHydro on 4710s. But, from what I've read in the manufacturer's product literature they seem to be just about the same...both work by shifting a lever on the steering column without need for clutching. Now, if you're comparing eHydro and PowerReverser, this is where the big difference is. Apart from the basics that I'm sure you're aware of (eg, pedal functions of eHydro), big advantage operationally of eHydro is its versatality when doing demanding FEL work. If you're thinking of constant, repetitive forward, backward movement using your FEL, then you're likely better off with eHydro and the 4710.
  3. #3
    Join Date
    Nov 2000
    Posts
    858
    Default Re: 5210
    <font color=green>I've read in the manufacturer's product literature they seem to be just about the same...both work by shifting a lever on the steering column without need for clutching</font color=green>
    The hydro on the JD 4000 series does not have a shifting leaver on the steering column,its all in the foot pedals on the right side of the tractor.
  4. #4
    Join Date
    Jan 2002
    Posts
    1,726
    Cambridge, New York
    Default Re: 5210
    You're right Hillbilly. I was referring to PowerReverser on the steering column, not eHydro. eHydro has pedals on the floor......sorry for the confusion, it was late last night when I was posting this. [img]/w3tcompact/icons/wink.gif[/img]
  5. #5
    Join Date
    Nov 2000
    Posts
    858
    Default Re: 5210
    Not,
    A problem.............thats what we are all here for.[img]/w3tcompact/icons/smile.gif[/img]
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
