Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    New Member
    Join Date
    Jan 2008
    Posts
    3
    Default 3520 vs 3220, turbo or no turbo
    Looking at these two; uses will be few hundred hours of flail mowing each spring and normal round the property tasks. They look essentially the same machine / engine with the exception of the turbo on the 3520. Is strapping a turbo on this block trying to get more out of the engine than originally designed for? How much will the extra heat effect the life of the engine?
    As to flail mower, just get the green one that the dealer is selling or hunt around?
    Thanks
    Bessemer
  2. #2
    Join Date
    Sep 2003
    Posts
    1,222
    Hartselle, Alabama
    Deere 2520
    Default Re: 3520 vs 3220, turbo or no turbo
    Decide what cutter you want to use, then see how much hp you need. The turbo will not harm the engine. JC
    JD 3320 LX5, KK rake and off brand box and rear blade. Millonzi grapple. Deere X495 for grass cutting.
    01 Ram 4x4 2500 CTD and 22' 12k trailer. Want a tiller and dump trailer.
  3. #3
    Gold Member
    Join Date
    Aug 2005
    Posts
    428
    West TN
    JD 3520 eHydro
    I have never felt the need for less power. LOL.
    2006 JD 3520
    300CX, Frontier BB2060
    1977 JD 214, 47 deck, 23" ags
  4. #4
    Join Date
    Aug 2006
    Posts
    174
    the 3320 engine is a bit bigger in cubic inches than the 35/37's with the turbo, they turboed the smaller 3120? i just got the 3320, for what i do..it is great
  5. #5
    Gold Member
    Join Date
    Aug 2005
    Posts
    368
    The Real Maine
    JD3520
    Hi bessemer,
    I have owned both of these machines and both were great (with the exception of a maligned recurring leaking rear main seal on the 3320--the first of the two).
    The 3320 seemed to give more low rpm grunt than the 3520, despite what the manual tells me... if you are planning on doing more loader and non-PTO work with the machine. There is no replacement for displacement--I preferred the 3320 doing loader work & boxblading under 2000 rpm's.
    IF PTO work is the predominant use of the machine (i.e. you have the engine revved up enough for the turbo to do it's job correctly), or you just love to hear the bang of the diesel & whine of the turbo there is a noticeable improvement in the 3520 over the 3320. Bushogging & tilling are where the extra torque (oh right horsepower...) really helped. No bogging down like before in the tall/sticky stuff.
    If the extra $$$ on the payment don't bother you, get the turbo
    Now those are an MX-5 and a KK 60 inch tiller... I have never used a flail mower, so idk what kind of resistance you run into with that implement.
    My .02 anyway. Both machines are a pleasure to operate. Good luck!
    browns40
  6. #6
    Platinum Member tomd999's Avatar
    Join Date
    Jul 2007
    Posts
    550
    Viva Manchvegas!
    '10 3320 cab
    Hiya,
    Get the turbo, you know you want to. To my ears any kind of blower sounds better than a stereo.
    My 2 PSI,
    Tom
    Big and little Green tractors, Orange tractors and one awesome brown dog.
    "Congelo nos opus, quantum punitor ingravesco"
    "Behold, like the wild azz in the desert, go I forth to my work"
  7. #7
    Platinum Member Killer_B's Avatar
    Join Date
    Sep 2004
    Posts
    578
    Kalamazoo Michigan
    John Deere 3320
    If you need a turbo, why not look at a 3720?
    KB
  8. #8
    Join Date
    Nov 2005
    Posts
    654
    Phillipston, MA/Guildhall, VT
    JD 2305/JD 3320
    I owned an open 3320 and now have a 3720 cab. More hp difference than the 3320 to the 3520 but very noticeable when I'm doing PTO work. Load work I don't think you'll notice too much when working the loader but when transporting the load it's noticeable.
    The 3320 does have the biggest block in the 3000 series. The 3120, 3520, and 3720 all have the same block (3120 naturally aspirated and the 3520 and 3720 differ only in boost and an intercooler on the 3720).
    If you don't mind spending the $$$ get the Turbo but as another post said, why not go all the way for the 3720.....
    "I'd rather be on my Tractor"
  9. #9
    Join Date
    Oct 2007
    Posts
    197
    SW Washington
    JD 3520 w/ 300CX
    In my case, I was going for the 3320 but the dealer had a 3520 that was custom ordered, then canceled, so it was almost cheaper to get the 3520 then the 3320. All in all though, I love this tractor and it does everything I want it to with plenty of power to spare.
  10. #10
    Super Star Member kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    11,089
    Westminster, MD
    John Deere 4110
    Welcome to TBN
    Do a search here for "Caroni", there is LOTS of talk here about them, you will have lots to read!
    John Deere 4110HST
    FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
    John Deere 4x2 Turf Gator
    View some of my projects/adventures in my Picasa Album
    Simple JDParts Tutorial HERE
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
