Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Jun 2008
    Posts
    14
    Default 2520 3 Point Hitch/Tire Interference - Real Issue?
    I narrowed my tractor selection to 3 choices - a new 2520 with FEL, new kubota B7800 with FEL, or used 2305 with FEL and rear tiller ($10K - great price). I'm really leaning toward the 2520 based on its edge in features (including position control), identical price to B7800 ($15,900), improved capabilities over 2305, and edge in financing (0 down vs 15% down on Kubota). The only concern I have is the continued posts about 3 pt hitch interference on the 2520 with turf/R4 tires. I went to the dealer today and confirmed this is not a myth - even with adjustment (needed even more on the unit I saw, but I was in a hurry over lunch) there is near tire contact at rest with no load. For you 2520 owners, should this be a deal breaker for me? I plan to use a box blade, tiller, and auger on the 3 pt. to do final grading for my .6 acre landscape project. Thanks!
  2. #2
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,924
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: 2520 3 Point Hitch/Tire Interference - Real Issue?
    Don't let it be a dealbreaker, but get the dealer to install the new updated arms that fixed the problem before taking delivery. And don't forget the I-Match
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  3. #3
    Join Date
    Feb 2008
    Posts
    125
    Southern MD
    BX2380
    Seezer, I had my dealer look into my tire rubbing issue for me, they put the tires in the wide position, and there is only very slight contact with the 3 pt raised to full height when going over uneven ground with a heavy implement. (at rest, there is about 1" of clearance on either side with implement fully raised). I'm still not happy about it just because there should be NO contact on a properly designed tractor, however, it isn't a huge deal and I don't think it rubs enough to hurt anything, including the tires. It would not dissuade me from buying the tractor (i.e. I'd do it again). Go talk to your dealer and tell them that you want the new arms as part of the deal, maybe they'll hook you up. Even if they don't go for that, I wouldn't rule the tractor out because of this "problem".
  4. #4
    Join Date
    Jul 2006
    Posts
    678
    JellyStone
    2520 John Deere
    X2
    Before I traded my 2520, my dealer had no problem getting the updated arms.
    Quote Originally Posted by kennyd
    Word of the day "balderdash"
    4520 John Deere w/400cx loader
    1987 Suzuki Samurai 6-1 transfercase jeep yj springs flipped locked front and rear. 33 super swampers
    1986 Suzuki Samurai SE.twin stick 4-1 transfercase flat belly, Niki carb
  5. #5
    Join Date
    Apr 2008
    Posts
    228
    MN
    JD 2520
    Make sure you get the new arms. Even though there might be up to an inch of clearance with some implements you'll never put chains on those tires without the updated arms. That's my issue. The clearance on mine with a JD back blade or my JD bush hog is about a half inch per side when fully raised. This quickly disappears when the sway adjusters don't stay tight and of course will not allow chains at all.
    BZ1
    From MN
  6. #6
    Elite Member
    Join Date
    Dec 2001
    Posts
    3,203
    Yep, get them to install the new arms. you may want to bemone/belabor the clearance issue and see if they will put them on as part of the deal to get you to buy the unit. This is a known issue and should be handled. Try to get the improved arms as part of the deal.
    here is a thread on this issue:
    http://www.tractorbynet.com/forums/j...installed.html
    Nuru
    JD 3520
  7. #7
    Join Date
    Oct 2004
    Posts
    121
    Alaska
    JD 2520
    BZ1
    Can you run chains on the front?
    I bought the wheel spacers for the front to move the wheel away from the bevel gear, but now my tires rub on the front end loader mount when turning.
  8. #8
    Join Date
    Apr 2008
    Posts
    228
    MN
    JD 2520
    AK, I assume that with the front wheel spacers I could run chains on the front. That's my plan but I haven't tried it yet. I do not have a front loader since I own a skid steer instead. I'm going to make my own front spacers since JD wants $70 a piece for them. If I couldn't have gotten my draft arms replaced for free I probably would have made spacers for the rear as well to solve that problem.
    BZ1
    From MN
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
