HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > John Deere > John Deere Buying/Pricing
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-19-2009, 03:56 PM   #1 (permalink)
New Member
Default 52" or 60" Rotary Broom for JD2520
Hi there -
I am considering getting a rotary broom for my 2520 & have a couple of questions -
Which model allows for hydraulic height adjustment - I know both will angle using hysraulics, but does which one can you adjsut the height of the broom using hydraulics and not just relying on the float wheels?
Considering that I currently have the front mount snow blower & attachment hardware - which would be most compatible given I already have the mounting frame.
Any help is truly appreciated - thx.
North of 60 is offline   Reply With Quote
Old 10-21-2009, 04:41 PM   #2 (permalink)
Gold Member
Default Re: 52" or 60" Rotary Broom for JD2520
I have the 52 inch rotary broom on my JD X475 Garden tractor, and it handles it with ease. Its really the PERFECT size for it, by the way it feels and works.
I think your 2520 would be happier with the 60 inch broom as far as physical sizing goes. But, remember if you plan on getting in narrow spaces, the wider one will be problems. I would measure the width of your 2520, and make sure to get a broom thats like 6 inches wider than the tractor, because they angle alot and then you would sweep the area you are driving over.
The brooms "should" both mount onto the JD quick hitch, and that should be power angle, and power lift. I know my garden tractor is.
__________________
JD 2520 --- FEL, I-Match, LX4 Rotary Cutter, DR Brush Chipper, Ballast Box, 71 Flex Planter!
Deadman is offline   Reply With Quote
Old 10-22-2009, 10:00 PM   #3 (permalink)
New Member
North of 60 I have a 2520 with a 60" broom. From what I read in your post you are looking to adjust the height of the broom using hydraulics? No you cannot the broom raises an lowers with hydraulics but to sweep you have to use the float wheels. But that is with the mount that is made for the broom. I would'nt do without my broom winter snow, spring sweeping stones out of the ditch dethaching the lawn mine gets a lot of use.
fountain42 is offline   Reply With Quote
Old 10-22-2009, 10:02 PM   #4 (permalink)
New Member
I forgot to say the 60 is needed to angle and be wider then the tires.
Old 10-30-2009, 03:51 PM   #5 (permalink)
jimgerken's Avatar
I have found that removing the gauge wheels ends up doing a lot less damage to the turf, when sweeping crushed rock off the lawn in the springtime. You have to run the hydraulics to keep the height about correct, but you have a couple inches of tolerance because of the flexibility of the nylon bristles. Before discovering this, I would use the gauge wheels, but found that they were sinking into the turf so bad, I started contemplating putting much bigger wheels on it.
jimgerken is offline   Reply With Quote
Old 11-03-2009, 06:56 PM   #6 (permalink)
Gold Member
The gauge wheels are so unpredictable. I use mine all by feel on the hydraulics.
Otherwise if there is a high spot, low spot, or soft ground, etc, the broom either digs in deep, or skips over the top.
__________________
Old 11-04-2009, 03:37 PM   #7 (permalink)
New Member
I have the 60" broom on my 2305 JD, and use it on my lawn for raking up acorns and apples, as well as getting gravel back where it belongs. I've found that the bristles are forgiving enough that I can put the broom almost all the way down and not hurt the grass...if anything, it dethatches it!
I agree that keeping the broom at the right level is tough on slopes (I have to brush the gravel from an incline...from a ditch back to the road). SO, I either put the broom down further than I need (which will scrape the grass, but again, I've found that the bristles are forgiving enough that it doesn't hurt it much if at all), OR I make several runs forward, rather than angling the broom and running parallel to the road.
Please note that the grass I'm using it on is not a baseball field or golf course, it's grass on a 3.5 acre lot that's fairly far away from the house, so if you're using this on VERY nice grass, I wouldn't gaurantee that this will be the best method for you.
wolfmanmd is offline   Reply With Quote
Old 11-04-2009, 03:44 PM   #8 (permalink)
New Member
North of 60, just a clarification on one of the posts.
The 60" broom uses hydraulics for agling from side to side, as well as up and down. HOWEVER, when I say "up and down," I mean that the broom will ANGLE up and down...it attaches via the quick-tatch system, and THAT remains fixed at the same height. So the broom can angle up and down, but it's not physically MOVING up and down.
Hope that helps.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.21229 seconds with 8 queries
